Posted: Mon Oct 11, 2010 12:56 pm |
I like it, but i would get a propper ported box made, the difference would be night and day.
Sam.
Posted: Mon Oct 11, 2010 1:41 pm |
Spanerman wrote: |
Sam. |
Yeh, thats the plan for the scooby
Steal the stuff out of this one, and put it in a proper mini tunnel box in the scooby
| Team Impossible Possible
Posted: Mon Oct 18, 2010 8:37 am |
Still got problems, the drivers side components are not working
Cleaned the earth point with p80 till shiny, took apart amplifier and lock tight'd the screws holding down earths in the amplifier and done up any other screws holding connections
The component amplifier is hooked up to the exterior fuse board though, could this be the problem? Or maybe a break in the wire, but it will cut in and out of playing
The passenger side will cut out sometimes, but rarely and before i cleaned up the earth i could hear my engine through the speakers?
Posted: Mon Oct 18, 2010 8:47 am |
addaz wrote: |
The passenger side will cut out sometimes, but rarely and before i cleaned up the earth i could hear my engine through the speakers? |
Where are you earthing it?
Posted: Mon Oct 18, 2010 8:53 am |
Ash wrote: |
addaz wrote: |
Where are you earthing it? |
Don't laugh but under the seat mount........ I know, its crap but i've been a tad to busy to change it
Posted: Mon Oct 18, 2010 8:54 am |
addaz wrote: |
Ash wrote: |
addaz wrote: |
Don't laugh but under the seat mount........ I know, its crap but i've been a tad to busy to change it |
Could be a poor chassis? I'd trying changing it temp.?
Posted: Mon Oct 18, 2010 8:56 am |
Ash wrote: |
addaz wrote: |
Ash wrote: |
addaz wrote: |
Could be a poor chassis? I'd trying changing it temp.? |
More than likely, or the terminal ring just isnt getting an earth
Apart from that, any ideas why drivers side cuts in and out? And is distorted before it cuts out?
Posted: Tue Oct 19, 2010 5:04 am |
though i still say liams saxo is one of the most mental street bassers around!! dont think im gonna persure the case of doing multiple subs anymore but will have to see yours looks good though
cheers
paul
Posted: Tue Oct 19, 2010 9:58 am |
addaz wrote: |
Ash wrote: |
addaz wrote: |
Ash wrote: |
addaz wrote: |
Apart from that, any ideas why drivers side cuts in and out? And is distorted before it cuts out? |
Are the RCA feeds okay? And got another amp to try it? Even if it means using a sub amp and feeding each speaker separately to test.
Posted: Tue Oct 19, 2010 10:06 am |
Ash wrote: |
addaz wrote: |
Ash wrote: |
addaz wrote: |
Ash wrote: |
addaz wrote: |
Are the RCA feeds okay? And got another amp to try it? Even if it means using a sub amp and feeding each speaker separately to test. |
Ash......
If i give them my 14001e, it will rape my speakers so much it will be unreal
But i will see if i can find one
Oh i've already changed my RCA leads, but i will swap them again and move the earth to a better place? Or use a smaller terminal so it actually touches the bolt?
Love ya ashh
Oh and yes, liams is mental, i aspire to that car
Posted: Tue Oct 19, 2010 10:08 am |
TheUniqueOne wrote: |
cheers
paul |
Liams saxo is cool, but nothing compared to Am's Chevvy or BassBoys Previa
Sam.
Posted: Tue Oct 19, 2010 10:20 am |
Spanerman wrote: |
cheers
paul |
Sam. |
You have to remember they are in a different league, much more space to work with
Please say your intrested in the shizzle, we need another mind on board
Any previous install's i should know about?
Posted: Thu Nov 11, 2010 12:38 pm |
Component amp fixed, bloody RCA's fall out from the vibrations from the install
But who cares, its coming out for a bigger one
Though be it, will i see much gain from doubling the power? But keeping the subs inverted but porting them correctly?
Posted: Thu Nov 25, 2010 3:01 pm |
Plans for the next install to hit 145db are added
Christmas is the starting date
Posted: Thu Nov 25, 2010 3:11 pm |
addaz wrote: |
Christmas is the starting date |
Whats your kit list mate?
