Posted: Wed Sep 08, 2010 1:17 pm |
ha ha, aye, it was reduced from over £400 so couldn't complain! It should be able to withstand it. Its a suction mount from eBay that I've taken to bits, and then some hollow black aluminium from B&Q with some U Bolts and a couple of nuts. Bolted to the seat so should be ok.
The old camcorder cut out mid session mate, will see what I can retrieve (if anything) and post it up. That second session was the best of the two, gave the tyres a good scrubbing and the oil a good heat up (147*c ). Oil cooler next methinks
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Wed Sep 22, 2010 7:34 am |
I've made another camera mount for the HD Camcorder now. Looks a little like a strut brace across the back of the car (bad times), but doesn't vibrate or wobble as much as my first attempt (good times). Bit more refining and it should be good to get some decent footage
Current wishlist is:
Aluminium sheet for underneath the car (aerodyamics / cooling)
Wavetrac ATB differential and Gearbox refurb
Rollcage (size tbc)
Polycarb windows
Battery relocation
Recaro Pole-Position seats (or similar)
Finish stripping interior
Fuel prices to come down 7mpg on track is fun, but means I run out of fuel too quickly!!
Posted: Wed Sep 22, 2010 12:18 pm |
Sounds good "Pole-Position" seats you say... Need to get some good footage determined to get some myself now !!
Posted: Thu Sep 23, 2010 12:35 am |
Yep, they're Kevlar, out of the Audi TT Quattrocento Sport,
Posted: Sat Sep 25, 2010 2:34 pm |
Ape wrote: |
Luke wrote: |
Love the wheels on it. Knew they would suit it from the photoshop.
You doing any more styling changes to it, or is all performance from here on in? |
I'd like to do a Red, Silver and Carbon Theme. The "S" Badges will be done in red, a carbon splitter, red engine hoses (Forge or Samco) and carbon dressy bits. But thats a long way off, I want the performance first, the tarting up is the last phase
Oh, I almost forgot - I'll be getting a Liquid Gauge for it too, shows Oil Temp, Oil Pressure, Boost, G Force, Fault codes etc, fits in the air vent and has full diagnostics etc. Fits neatly in the Drivers side Air Vent:
Cheers for the comments all, the wheels are fantastic lol. A real Marmite Modification |
where are you getting the guage from mate
Posted: Sun Sep 26, 2010 4:57 am |
I bought the gauge from eBay, they won't fit 206's. They use VAG COM which is VW/Audi/SEAT specific.
Posted: Sun Sep 26, 2010 9:32 am |
The cars looking lovely mate, some very innovative touches!
What size is your numberplate and where did you get it??
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Wed Oct 20, 2010 10:49 am |
I see thi car all the time in Soturport / Kiddemrinster. DO you remeber being stuck behind ppl pushing a grey civic on the stourport road lol? then you ragged it past :L??
Posted: Thu Oct 21, 2010 3:42 pm |
civic>206 wrote: |
I see thi car all the time in Soturport / Kiddemrinster. DO you remeber being stuck behind ppl pushing a grey civic on the stourport road lol? then you ragged it past :L?? |
Ape ragging it not on a public road..
Posted: Fri Oct 22, 2010 3:12 pm |
The plate's a 3/4 size on the front
I do remember the civic although I didn't rag it past, too much traffic and no real need to rag it, rarely take it over 4000rpm as there's no need to
Posted: Fri Nov 19, 2010 1:07 pm |
Posted: Fri Nov 19, 2010 1:27 pm |
Nice thats going to look very smart. Will you be changing the wheel colour aswell?
Posted: Fri Nov 19, 2010 1:30 pm |
I'm unsure at the moment. I might do, but I'm unsure to what. Back to Silver, Yellow, Black or keep them red.
Posted: Fri Nov 19, 2010 1:32 pm |
Is this a track car? Then is such decoration really needed?
Posted: Fri Nov 19, 2010 1:35 pm |
In a way yes, it's cheaper than a respray. And doing the Modball Rally warrant's some silly graphics and such as you get sponsors and whatnot for the trip.
