Latest: DanDan17
Overall: 17128
Online Now [184]:
Visitors: 183
Today: 20806
Total: 100621218
Forums › The Car › 206 Talk › 206 HDi TD 2.0 Niggly Problems
Smokes
PostPosted: Fri Oct 29, 2010 3:14 am Up
Hello
My first post on the forum Surprised
I know a lot of us go on about rattly Pugs with niggly problems you either like or hate them, I used to love my 205GTI
I have just got a 206 HDI 2.0L T Diesel X Reg and have a couple of niggles
The rev counter sometimes sticks then behaves itself works ok then spits the dummy out again, apart from a clock cluster replacement does anyone know of a fix?
My rear wheel bearings are starting to make a noise, can these be greased like the older type of bearing or do they need replacing, if so would ebay number 380252803275 for HDI ESTATE 9/02> fit & last for a while without problems
central locking works both doors but have to open the passenger door from inside
With this being my first Diesel what type & how much engine oil is recommended
Sorry for all the questions but I did not want to write posts allover the forum
Smokes
206 2.0 HDI T Diesel
eddrj
PostPosted: Fri Oct 29, 2010 5:08 am Up
Hi and welcome its 4.5 litres of oil and 10w40
Old car 2000/ 206 2.0 hdi.
dturbopeck
PostPosted: Fri Oct 29, 2010 6:02 am Up
Will have to replace wheel bearings, rev counter could be a sensor fault, and you would need to strip door down to find fault with lock!
Smokes
PostPosted: Fri Oct 29, 2010 7:18 am Up
Thanks for the replys would the bearings I mentioned in the first post be ok to fit? or have they got to be for a 3 door 206
Smokes
PostPosted: Fri Oct 29, 2010 7:31 am Up
If it's bothering you, get a new cluster, it must have a lower mileage than your existing one and it also must come from a non-plexed car
Yeah they some times dry up, and they can be re-greased, i've just done mine
Couid be the solenoid failing, but first take the interior pannel off and make sure all the wires and rod are connected. Also try testing the wires with a multimeter to ensure voltage is going to the lock
4.5 litres if you are changing the filter as well. there's 1.4 litres between the min and max mark. Use Total Quartz 7000 10w40
Smokes
PostPosted: Fri Oct 29, 2010 7:47 am Up
Hi Lee
Thanks very much for taking your time to send a detailed reply, very much appreciated. I am looking for someone honest & reliable to do a couple of jobs my 206, where do you live?
Pete
PostPosted: Fri Oct 29, 2010 9:07 am Up
I'm from Sheffield. I'm not a mechanic, I'm a business student, its more of a hobby for me.
Smokes
PostPosted: Fri Oct 29, 2010 5:28 pm Up
No Problem
