Posted: Sat Oct 30, 2010 9:23 am |
Anyone know the size of it? The one that holds the topmount onto the shock?
Is it a 21mm - I've looked on Service Box and cant find the size - well it's not listed just the item number
Thanks!
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Sat Oct 30, 2010 9:27 am |
22mm mate, you'll need a deep offset spanner.
Posted: Sat Oct 30, 2010 9:35 am |
Thanks dude
| The Cars:
Posted: Sat Oct 30, 2010 9:44 am |
I found getting hold of such a spanner quite difficult. Halfords do one that will just about reach deep enough.
Posted: Sat Oct 30, 2010 9:47 am |
Edward wrote: |
I found getting hold of such a spanner quite difficult. Halfords do one that will just about reach deep enough. |
Is that the Halfords Professional Ring Spanner 22x24mm?
www.halfords.com/webap...yId_165469
| The Cars:
Posted: Sat Oct 30, 2010 9:51 am |
Trade Rating: +31
Posted: Sat Oct 30, 2010 9:53 am |
You can go to any plumbing or engineering shop and grab a hold of a 22mm deep offset spanner very easily!
Posted: Sat Oct 30, 2010 10:01 am |
Cheers B I'll try that one If it snaps I know it was a crappy make haha!
| The Cars:
Posted: Sat Oct 30, 2010 10:08 am |
Yes, It's not perfect but will do the job.
Posted: Sat Oct 30, 2010 10:10 am |
Thanks Edward aslong as the bolt comes off thats all I care about - well that and the spring not slapping me in my face
| The Cars:
Posted: Sat Oct 30, 2010 10:21 am |
Trade Rating: +13
I used a 22mm socket clamped in mole grips.
And an Allen key throughout the socket into the shaft.
Easy peasy!
Posted: Sat Oct 30, 2010 11:49 am |
some times you can get the bolt moving without the allen key i have found on some cars
Posted: Sat Oct 30, 2010 11:50 am |
Trade Rating: +31
Depends on age/use i suppose Ben
Posted: Sat Oct 30, 2010 11:54 am |
Brian wrote: |
Depends on age/use i suppose Ben |
yep ture, my pug y reg standard ones and a r reg vectra and mates saxo, didnt need an allen key, just twisted off. tho most cars i have worked on you do, just have to be lucky i suppose
i found lossing them off while weights on car helped (not all the way obviously)
Posted: Sat Oct 30, 2010 11:58 am |
Getting it off isn't the problem. It's making it tight when reassembling it.
