Posted: Mon Nov 08, 2010 11:30 am |
ive took the back off the key pob to see which type of battery it took, but couldnt see a code on the back, i didnt want to takee the battery out in case the key fob wouldnt work again lol
ive had a look on ebay but there are so many ones to choose from all the same sizee but with differnt codes
does any on have an idea which code battery is correct for my 206
cheers
| | ![](images/spacer.gif) |
Posted: Mon Nov 08, 2010 11:31 am |
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Mon Nov 08, 2010 2:23 pm |
they do usually have a code on them like cr2025 or similair
Posted: Mon Nov 08, 2010 2:25 pm |
jewellers will test it and change it for you if needed, cost me about 30p last time i went. ![Razz Razz](images/smiles/icon_razz.gif)
Posted: Tue Nov 09, 2010 6:56 am |
It will be either CR2016 or CR2025.
Make sure the button doesn't get pressed when the battery is off
and you might get away without needing to re-program it afterwards.
