Posted: Tue Nov 09, 2010 6:38 pm |
im in talks with a guy who works with metal he makes a removal tool for the Alfa romeo, so ive asked him about one for a 206 just after how much interest there would be for one, it will work the same way as the 30mm socket .... so would you be interested in one?
they wont be expensive either!! around the 20 pound mark + p&p
Posted: Tue Nov 09, 2010 7:00 pm |
Wouldn't mind seeing a pic,
Posted: Tue Nov 09, 2010 7:21 pm |
it would work like a 30mm socket, so hes going to make you a 30mm socket is there any point?
Posted: Wed Nov 10, 2010 3:01 am |
im not totaly sure hes going to send me pictures i gess the part which works as the 30mm socket will be threaded
Posted: Wed Nov 10, 2010 4:54 am |
Interested.
Posted: Wed Nov 10, 2010 4:58 am |
Posted: Wed Nov 10, 2010 6:01 am |
Yep i guess just like that i am gonna invest in one
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Wed Nov 10, 2010 7:44 am |
why do you need that??
Posted: Wed Nov 10, 2010 7:46 am |
Seabook wrote: |
why do you need that?? |
I'd guess its easier than hammering it out.
If it works..
Posted: Wed Nov 10, 2010 7:49 am |
Nothing is easier than using a sledge hammer. Seized torsion bars need brute forced not delicate little tools.
Posted: Wed Nov 10, 2010 7:50 am |
Big_Rich180 wrote: |
Seabook wrote: |
If it works.. |
Edward wrote: |
Nothing is easier than using a sledge hammer. Seized torsion bars need brute forced not delicate little tools. |
Posted: Wed Nov 10, 2010 7:51 am |
Seabook wrote: |
Seabook wrote: |
If it works.. |
Edward wrote: |
Personally i wouldnt bother at all, id get some one else to do it
Posted: Wed Nov 10, 2010 10:54 am |
True hammer is Easier, tryed the bolt method once and snapped the bolt so never tryed it that way since.
Posted: Thu Nov 11, 2010 3:18 am |
how about if i had a a very high tensile bar made with an m10 thred on one end a large nut half way down (welded into place) to wind it into the torsion bar and a flat surface on the other end to hit with a BIG hammer, atleast then you wont damge the threads while hitting the torsion bar
Posted: Thu Nov 11, 2010 3:22 am |
Sounds like a idea, I normally push a smaller bolt into bar and hit on that (if you use right size the head gets disformed and can't get it out)
Can you draw a diagram?
