Forums › The Car › 206 Talk › torsion bar removal tool |
Posted: Thu Nov 11, 2010 3:31 am |
a 4kg sledge is best, the nut and socket method will only work if its been out a few time and then they is no staying it will work. id like to see it work on a car that 10+ years old
Posted: Thu Nov 11, 2010 3:41 am |
charlie-52 wrote: |
how about if i had a a very high tensile bar made with an m10 thred on one end a large nut half way down (welded into place) to wind it into the torsion bar and a flat surface on the other end to hit with a BIG hammer, atleast then you wont damge the threads while hitting the torsion bar |
You are still screwing something in the TB though. Any impact less that perfectly straight runs the risk of snapping the threaded part in the TB.
Posted: Thu Nov 11, 2010 4:20 am |
I'd like to see a pic, tried mine the other week, got peed off after 3 hours of no movement at all and about 4 cans of wd40. To top it off it started chucking down wit rain lol
Posted: Thu Nov 11, 2010 8:34 am |
Seabook wrote: |
why do you need that?? |
iv done loads just need a soft bass/copper punch (got one just smaller than the hole in the axle and a big hammer
patience and being careful are the main keys never not been able to get one out yet
Posted: Mon Nov 15, 2010 3:18 am |
"patience and being careful are the main keys" totaly agree
so its just eaiser to get a copper hammer and well hit it ..... 1st time i did mine i started at 10am saterday stopted at 5 ish then again at 10 on sunday and was done by arround 3, i then relised it was too low and it only took me an hour to do it again
