Can anyone help....... i have brought a 206 and the day after i went on a 60 mile round trip and on the way about 20 min into the trip the car felt like it pulled...lost power and a kind of bang from the exghust...i also had some lights come on and there is one i cant find in my book ...its orange square with squiggles around it too the right of the dash lights..... After i pulled over gave it a few minutes it seemed ok... it was also ok on the way home how ever...today i popped into town and when i came home when i approached the car park the same light came on i pulled into a space and when the car was still the revs went really high (4) and smoke came out of the exghust...i turned it off and left it for 20 mins went back and turned the engin over and the revs are still high sitting at about 3/4 and it sounds really loud......
Sounds like a faulty idle control valve, you could clean it, I've heard that normally helps, do a search and there should be some more info
good luck with the new pug!
Cheers
hobnob48
Posted: Mon Nov 15, 2010 9:50 am
If that dont work check out the flywheel sensor may be faulty
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
