Latest: Worthy967
Overall: 17143
Online Now [625]:
Visitors: 624
Today: 122046
Total: 115455141
Forums › The Car › 206 Talk › Engine Swap
Engine Swap
Jake
PostPosted: Tue Nov 16, 2010 1:26 pm Up
I know this has probably been covered loads of times Laughing But i have a phase 1 1.4 8v and was just wandering what engines i could drop straight in?
Jaykerz.
PostPosted: Tue Nov 16, 2010 1:27 pm Up
if its preplexed, probably easy to stick unless you want to remove whole wiring and replace with multiplexed.
Or do you mean other car engines like the gti-6 etc?
Jake
PostPosted: Tue Nov 16, 2010 1:29 pm Up
You mean if its easier it probably just easier to stick with my engine? Im not to sure to be honest i was just looking at options, would consider anything. But without changing all the wiring lol.
Jaykerz.
PostPosted: Tue Nov 16, 2010 1:42 pm Up
If its preplexed, then its easier to stick with preplexed engines like the early 1.6, 2.0 gti etc
But if you want something like a 180 engine then its more difficult as whole wiring needs changing in car as its multiplexed.
a gti-6 engine will fit fine in a preplexed for sure as racerxbon did it.
What year is your pug?
Jake
PostPosted: Tue Nov 16, 2010 1:44 pm Up
It is a Y so 2001
Jaykerz.
PostPosted: Tue Nov 16, 2010 1:46 pm Up
A phase 1 1.4 8v will drop straight in.
Jake
PostPosted: Tue Nov 16, 2010 1:50 pm Up
Well done that was helpfull, Really worth posting.
Jaykerz.
PostPosted: Tue Nov 16, 2010 1:51 pm Up
I have a pre-plexed GTi engine for sale Wink
Reading isn't too far from Salisbury.
PostPosted: Tue Nov 16, 2010 2:10 pm Up
Very Happy It answered your question exactly.
Your engine, the phase 1 1.4 8v is the only one that will drop straight in.
Jamie
PostPosted: Tue Nov 16, 2010 2:17 pm Up
Not true, so will the 1.1 and 1.6 8v Wink
Engines aren't multiplexed anyway, you can swap sensors to adjust for the multiplexing.
PostPosted: Tue Nov 16, 2010 2:22 pm Up
What He Said
an engine in an engine in both ways, its the bits around it like sensors that maybe slightly different.
PostPosted: Tue Nov 16, 2010 2:29 pm Up
He said ''But without changing all the wiring''.
So as a no hassle straight swop, I still think like for like is the easiest solution.
Jake
PostPosted: Tue Nov 16, 2010 2:30 pm Up
How much do you want chris?
Jaykerz.
PostPosted: Tue Nov 16, 2010 2:35 pm Up
if you put it that way your right,
but changing a few sensors is easyer than getting the engine in and out so its not hard.
Laughing
no_offences
PostPosted: Tue Nov 16, 2010 2:39 pm Up
a gti 138 will be easiest engine to fit without problems then the gti 6, bigger so be a little harder, then if you want a total p**s take go for the 180 ive heard its amazingly annoying to fit to a pre plex
Signature removed due to size
