Latest: Mr-Koekwaus
Overall: 17125
Online Now [368]:
Visitors: 367
Today: 30388
Total: 99455904
Forums › The Car › 206 Talk › 180 Oil usage/smoke
180 Oil usage/smoke
pat_986
PostPosted: Tue Nov 16, 2010 1:47 pm Up
Hi all
I have done a few searches but to no avail.
I have a 54 plate 180, with about 85k on the clock.
I have only had it a few months, and have done one oil change.
My question is, how much oild does your gti/180 use?
I would say mine is using 1l about every 3-4k, seems like a little much to me, but do know some engines do use oil.
Also, even when the engine is @ normal operating temp, there seems to be a bit of smoke out the exhaust, the same type you see when the engine is cold and its cold outside?
Any comments?
2004 Flamenco red GTi 180
pat_986
PostPosted: Tue Nov 16, 2010 1:49 pm Up
Oh, and what I was going to say, the two 'problems' made me think valve stem seals???
rubyspilot
PostPosted: Tue Nov 16, 2010 2:06 pm Up
Sorry to hear that buddy....a litre every 3k is a tad ott.
If the smoke is blue you might be lucky and changing the valve stem seals would be my first choice.
If not then it's getting past the rings( serious bad news)
All this notwithstanding a leak of course
Antix
PostPosted: Tue Nov 16, 2010 2:19 pm Up
Custom - Red Stars
My red 180 rarely used oil inbetween services (6 monthly approx).
I never topped it up, and it never smoked either Confused
pat_986
PostPosted: Tue Nov 16, 2010 2:59 pm Up
Hmm not good news!
I guess I will just monitor it over the next few tho miles.
I suppose if the head does need to come out, at least it would be a good excuse to port polish and add cams!
Are there any other reasons for white/steam like smoke out the exhaust?
PostPosted: Tue Nov 16, 2010 3:00 pm Up
port polish virtually is a waste of money
pat_986
PostPosted: Tue Nov 16, 2010 3:06 pm Up
On the 180, or any engine?
Why would you say that?
hotham15
PostPosted: Tue Nov 16, 2010 3:17 pm Up
250ml for 10 000 miles... for me... She sounds like a heavy drinker!
GTi 180 - Black - GP04 *** - Standard + Typhoon, CL5+ Breaks & Front Splitter.
rubyspilot
PostPosted: Tue Nov 16, 2010 3:34 pm Up
pat_986 wrote:
Hmm not good news!
White smoke is water in the combustion.....might be headgasket.
Blue is oil
Black is fuel.
You might be lucky and get away with a headgasket.....might explain the oil loss too......check for the white emulsion under the oil filler.
pat_986
PostPosted: Tue Nov 16, 2010 4:06 pm Up
rubyspilot wrote:
pat_986 wrote:
Hmm not good news!
Blue is oil
Black is fuel.
Cheers. oil cap is clean, and im not loosing any water, so doin't think its HG.
Will have to check the colour of the smoke a bit better.
PostPosted: Tue Nov 16, 2010 4:35 pm Up
did you redline your car a lot?
pat_986
PostPosted: Tue Nov 16, 2010 4:49 pm Up
Do I, very very rarely. Most of my driving is in traffic or mway.
PostPosted: Tue Nov 16, 2010 5:00 pm Up
could ask the garage to do a compression test
oil could be leak through worn piston and get burned
PostPosted: Wed Nov 17, 2010 3:06 am Up
Is an induction kit fitted? Any breather pipes blocked?
sri16v
PostPosted: Wed Nov 17, 2010 12:49 pm Up
doesnt the 180's owner manual mention about the engine using .5 of a litre every 1000 miles, or something around that figure?
I know mine uses a little between servicing, but mine does get driven hard.
2004 GTi 180
