Latest: sparrowdclxvi
Overall: 17139
Online Now [142]:
Visitors: 141
Today: 31199
Total: 113231159
Forums › The Car › 206 Talk › Has Anyone Used A Pump For An Oil Change?
steevie_b
PostPosted: Tue Nov 16, 2010 7:40 am Up
I'm wanting to do an interim oil change but where I am now is pretty difficult, not exactly easy to jack it up etc. and I don't fancy paying someone to do it...
I've looked online about these vacuum pumps (particuarly the Pela 6000) which suck the oil out through the dipsitck hole. Some other forums say that they're pretty good and it's the only way to change oil on a Smart car.
Has anyone had any experience with these on a 206?
Steve
dturbopeck
PostPosted: Tue Nov 16, 2010 7:45 am Up
Yeah some cars don't have sump plugs, so using a pump is the easy way out of it, however I wouldn't do it as you will never get all the oil out with a pump.
PostPosted: Tue Nov 16, 2010 7:48 am Up
Just buy some ramps...Machine Mart do them for about £25 a pair.
steevie_b
PostPosted: Tue Nov 16, 2010 7:51 am Up
I was only planning on using it for an interim oil change, I usually do a main one in my GF's dad's workshop (he has a pit) in the spring. Some people reckon they can get 4l out of their sump which has a total capacity of 4.2l, which I don't think is too bad.
PostPosted: Tue Nov 16, 2010 8:07 am Up
Can't you reach your sump plug with the car on the ground?
PostPosted: Tue Nov 16, 2010 8:10 am Up
What He Said
even with my lowered car i just jacked it up a bit, undone the plug and lowered it down till it was empty. Laughing
PostPosted: Tue Nov 16, 2010 9:53 am Up
Or just park cockhide on the kerb
wardie_206
PostPosted: Tue Nov 16, 2010 9:56 am Up
great idea that Very Happy
thats wat i done, cheap and effective lol
T_bandery
PostPosted: Tue Nov 16, 2010 10:00 am Up
Jack up a bit, slide a brick or two under the front tyres.... easy
rubyspilot
PostPosted: Tue Nov 16, 2010 1:24 pm Up
Trouble is ....that last .2 litres has all the nasties in it at the bottom of the sump
PostPosted: Tue Nov 16, 2010 1:28 pm Up
The nasties should be in the filter.
M60SHW
there you go job done and come in handy for all sorts lol
rubyspilot
PostPosted: Tue Nov 16, 2010 1:34 pm Up
LOL if there's no nasties in the bottom of your sump.......I'll eat my air filter lol
PostPosted: Tue Nov 16, 2010 2:31 pm Up
Do you want ketchup with your filter?
PostPosted: Tue Nov 16, 2010 2:35 pm Up
i agree with edward, once the oil is in circulation, all the crap should be trap in the filter lol
