Latest: sparrowdclxvi
Overall: 17139
Online Now [406]:
Visitors: 405
Today: 31320
Total: 112419280
Forums › The Car › 206 Talk › fuel injection
fuel injection
XSIcheeseman
PostPosted: Fri Nov 19, 2010 6:26 am Up
hi does anyone know what the common faults are with peugeot fuel injection systems and does anyone know where to find a wiring diagram for the fuel injection system . its for my mechanics course .
PostPosted: Fri Nov 19, 2010 6:29 am Up
public.servicebox.peug...com/docpr/
Login: AP94609342
Password: 206info
XSIcheeseman
PostPosted: Fri Nov 19, 2010 6:32 am Up
only thing is i cant read french lol
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
PostPosted: Fri Nov 19, 2010 6:37 am Up
You can change the language, top right hand corner of the login screen is a drop down box.
XSIcheeseman
PostPosted: Fri Nov 19, 2010 6:47 am Up
oh yeah lool
New and Improved!
New Project
PostPosted: Fri Nov 19, 2010 7:10 am Up
Fuel injection is part of the whole engine management system.
Most common faults would be with lambda sensors or the ECU itself. All the throttle body sensors also help run the engine so you could add idle control valves and also coolant temperature sensors. Crank sensors can also fail but this doesn't happen too much.
