Online Now [518]:
Visitors: 517
Today: 133597
Total: 128350981
Forums › The Car › 206 Talk › Rear brake piston wind back
tyrone81
PostPosted: Tue Nov 23, 2010 1:25 am Up
Needing to replace rear disks this week, Just wondering about getting the piston back in. Can i just use a pair of long nosed pliers? I have done this before, not sure what the 206 is like.
Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
EuroPeugeot
PostPosted: Tue Nov 23, 2010 1:56 am Up
Yup, definitely mate. I used a thick long screw driver Smile
PostPosted: Tue Nov 23, 2010 3:57 am Up
Yep, I too used a screwdriver when doing them on my old 206.
kieron
PostPosted: Tue Nov 23, 2010 5:10 am Up
i will be replacing mine this week , ive found a seller on ebay who will do a good deal on discs and pads all round. it was just the tool i was worrid about but if you can wind them back in then its a bonus
Account suspended
tyrone81
PostPosted: Tue Nov 23, 2010 11:04 am Up
Chears guys.
Ernie
PostPosted: Fri Nov 26, 2010 2:37 am Up
if they are the same set up as Renault use a g clamp.
Wile tightening the gclamp turn the piston clockwise wile applying pressure.
The piston will go back in so repeat the prosess till its fully back in.
Hope that helps.
\"It just went bang\"
