Online Now [470]:
Visitors: 469
Today: 157753
Total: 156509724
Forums › The Car › 206 Talk › How Do I Remove Passenger Window?
Forum Index › 206 Talk
JDave
PostPosted: Wed Dec 01, 2010 6:57 am Up
Hi,
As you may know my car was broken into and my passanger window was smashed. Got one sorted in a scrappy, just need to know how to get it lol.
So what tools do I need, how long will it take and more importantly - what do i do?
JD
Click To View My Project
PostPosted: Wed Dec 01, 2010 7:07 am Up
Breaking it is one way...
I'll leave now Razz
PostPosted: Wed Dec 01, 2010 7:08 am Up
If its like a 205, then a selection of sockets, 10mm sounds right & screwdrivers.
Undo the window mechanism and pull it up and out, the seals may need pulling off too.
PostPosted: Wed Dec 01, 2010 7:53 am Up
Take the door card off. The window on the front is just held in by two plastic clips that you just flick off. If the mechanism needs to come out, then you need a drill to drill the rivets
PostPosted: Wed Dec 01, 2010 9:17 am Up
Is it really that simple/different on the 206!
PostPosted: Wed Dec 01, 2010 9:35 am Up
Yep, 10 mins tops. Infact Im positive you don't have to take the mechanism out, you might have to take the seal off on the window to give you that bit extra room.
I converted rear windows from manual to electric in an hour
bellevuespares
PostPosted: Wed Dec 01, 2010 10:40 am Up
lee is correct
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
JDave
PostPosted: Wed Dec 01, 2010 12:58 pm Up
Where are the plastic clips that I " flick off"? Colour are they?
PostPosted: Wed Dec 01, 2010 1:19 pm Up
They are white. If you wind the window down about a 1/4, you will see them at either side of the window. There are two.
JDave
PostPosted: Thu Dec 09, 2010 3:48 am Up
Phoned the scrappy to pick it up and they guy said they only have electric windows, and I have rolling windows, is this a problem?
Also, he said I need a battery charge to move the window cause its a scrap car and I need to "drop the mechanism"
Help me please
VorTechS
PostPosted: Thu Dec 09, 2010 3:53 am Up
Staff - Vortechs
The clips are no different (there might only be one on the rear IIRC), but you do need to drop the window. There's an outside chance they may be talking about the front windows being electric and the rears may be wind down, but sounds like you better get hold of a spare battery!
And removing the window seal at the bottom is the quickest / easiest way to be able toget the window out once you've unclipped it.
JDave
PostPosted: Thu Dec 09, 2010 5:10 am Up
Oh sounds awfly confusing for a noobie like me. I will give it a go.
