Latest: ArtistKS
Overall: 17145
Online Now [74]:
Visitors: 73
Today: 24704
Total: 116012412
Forums › The Car › 206 Talk › What i need for home diagnostic?
markob
PostPosted: Mon Dec 06, 2010 4:14 am Up
I have p206 y2000, this model as i read doesnt have OBD2 connector, but it has ?
I have software Peugeot Planet 2000 v22.14 (2010) , so i need interface, wich and so?
TNX
Slovenia
kieron
PostPosted: Mon Dec 06, 2010 5:37 am Up
not sure with pp2000 but i just use a ELM327 interface and use touchscan software
cgi.ebay.co.uk/ELM327-...58835b9c5f
you can do all faultcodes etc but cannot go into the bsi or the breaking system etc like pp2000
were did you get the pp2000 from?
EDIT****
LEXIA is what you use
shop.ebay.co.uk/?_from...Categories
Account suspended
leon206
PostPosted: Mon Dec 06, 2010 6:13 am Up
is this one ok ? its at least £20 cheaper and looks the same?
cgi.ebay.co.uk/ELM327-...3a60f9cd33
peugeot
skard
PostPosted: Mon Dec 06, 2010 6:34 am Up
you'll need this if you want PP2000 functionality cgi.ebay.co.uk/DIAGNOS...1c17b0c88a
markob
PostPosted: Mon Dec 06, 2010 7:39 am Up
Why do i need so many connectors? And it sexpensive 120 pounds, for other cars interface, obd2 and software cost 30eur
Slovenia
kieron
PostPosted: Mon Dec 06, 2010 7:49 am Up
you can use cheaper one to just clear fault code fine but if you want to go into detail and get the full use out of PP2000 you need what me and skard have just put up lexia
but if your not botherd use a cheap elm327 it will work ive been using it for sometime and got a fair few different programs for its use
Account suspended
glenpring
PostPosted: Mon Dec 06, 2010 8:31 am Up
how can i check if my vehicle is OBD2 Compliant
i have a 307 1.4 hdi
skard
PostPosted: Mon Dec 06, 2010 10:40 am Up
you don't need ALL the leads, but you'll need the multiplexer box and most likely the round plug-OBD plug (with green plastic connector).
this is the one i have, other leads are for older cars and taking real time battery info etc so you may not need them. you can access the BSI, clear faults with this type of cable.
it's still well cheaper than a genuine one!! i have a genuine VCDS aka VagCom and that costs at least twice what this one does.
two or three trips to the dealer and it's paid for.
markob
PostPosted: Mon Dec 06, 2010 11:27 am Up
It hink that i need conector vith trapez shape at the top and on the bottom connector is flat, OBD2 conector is on trapez shape. Must check
Slovenia
markob
PostPosted: Sun Dec 12, 2010 4:22 am Up
This is my connector, wich is it?
Slovenia
