Online Now [41]:
Visitors: 40
Today: 103511
Total: 117353368
Forums › The Car › 206 Talk › could i make these fit?
drunknmunky
PostPosted: Tue Dec 07, 2010 7:23 am Up
Can someone tell me if it would be possible to fit these on my 206 gti 180 as i am looking at euro styling my car
What would be needed to make them fit if it is possible to make them fit?
cgi.ebay.co.uk/ws/eBay..._500wt_715
PostPosted: Tue Dec 07, 2010 7:25 am Up
Hub adapters to make them from 4x100 to 4x108.
PostPosted: Tue Dec 07, 2010 7:30 am Up
Something like these: www.ultratuning.com/en...8-651.html
drunknmunky
PostPosted: Tue Dec 07, 2010 7:32 am Up
thanks Smile
PostPosted: Tue Dec 07, 2010 7:36 am Up
you probably want to checkthe bore size of the wheels too.
pug are 65.1
However they only need to be 10mm adapters. Offset needs to be down to ET25 (so 10mm adapters, the ones in that link are 20mm). 20mm will work, just make them sit out of the arches a little bit.
drunknmunky
PostPosted: Tue Dec 07, 2010 7:45 am Up
yeah well the arches would be getting flared anyway and the tyres would be stretched on so maybe the 20mm ones would work fine?
although it will be lowered as low as can go so not sure if i should find 10mm ones then?
I will e-mail about the bore size too thanks
Uz
PostPosted: Tue Dec 07, 2010 8:00 am Up
cgi.ebay.co.uk/2x-Hubc...4ce95b7a12
^^ you'll need these but the bore needs to be 57.1 which is VW fitment...but depends on what cars their bought for. If there bought for a Renault the ones in the link are perfect.
europug
PostPosted: Tue Dec 07, 2010 8:32 am Up
tbh mate doubt you will need to flair arches only if your goin 9s on rear, i would have thought 8s would fit, my front are 8s with gti wings
