Online Now [78]:
Visitors: 78
Today: 45585
Total: 116781721
Forums › The Car › 206 Problems › Glowplugs on a 2.0 HDi
Joe406
PostPosted: Tue Dec 07, 2010 4:37 am Up
My D Turbo will not start in this cold weather, even after 3-4 glowplug lights before turning over. The battery seems to be fine and manages to turn the car over for a while.
The breakdown bloke said he thinks its the glowplugs, so I am going to buy a set and try it.
I was just wondering if they are in a difficult location in the engine and whether its an easy job on a 206?
Peugeot 206 D Turbo
davek
PostPosted: Tue Dec 07, 2010 7:40 am Up
I don't think it's an easy job.
IIRC there was a video on Youtube by a mechanic who shows you how to change them on a diesel van.
BTW: My car is garaged but still takes a few goes to fire up.
troy
PostPosted: Tue Dec 07, 2010 12:49 pm Up
hell of a easy job, but id check them first as yuo dont wont to end up having one snap in the head. you do this by puting a live to the end on the glow plug and seeing if it gets grounded, simplest way is with a power probe, these are only about 10 to buy and come in handy allot
just abit of info but i work in a garage and 4 of us have cars with the 2.0 hdi in it, all are having trouble starting in the morning first time, everything is ok with all opur cars, i just turn the key on and off 10 times and it starts a little rough but its ok.
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
dturbopeck
PostPosted: Tue Dec 07, 2010 3:20 pm Up
And if glow plugs dont fix it you have a fuel problem!
troy
PostPosted: Tue Dec 07, 2010 3:36 pm Up
here you go buddy, the glow plugs are circled, there is a 8mm at the top with a wire on it, remove that and then you will see the glow plugs which i belleive is a 10mm, make sure you let lots of wd40 soak in before you remove them
2.0 hdi 90
challenger alloys
braided brake lines
de-egr'd
kieron
PostPosted: Tue Dec 07, 2010 3:59 pm Up
11mm i think plugs are?
Account suspended
PostPosted: Tue Dec 07, 2010 6:06 pm Up
Wink
panason1c
PostPosted: Wed Dec 08, 2010 4:49 am Up
Better chance of them coming out in one piece if you have the engine at full working temp prior to removal.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Joe406
PostPosted: Wed Dec 08, 2010 6:56 pm Up
Thanks for the help the guys, thats why this forum is so good because people are always willing to help and offer useful information. Smile
Peugeot 206 D Turbo
MPorter13
PostPosted: Sun Jun 17, 2012 7:12 am Up
My hdi had this problem, changed the glow plugs and it didnt fix it, end up getting a new battery and never had a problem since
MPorter
fragg
PostPosted: Sat Sep 07, 2013 12:20 pm Up
Thanks Troy the picture helped me out alot
cosmicdance
PostPosted: Sat Sep 07, 2013 3:34 pm Up
Your HDi won't actually use the glow plugs until it gets a lot colder, like down to 0 degrees.
These engines just don't need them to start until it is very cold as they are very high compression and efficient.
Andy
Andy
