Latest: Andyblue64
Overall: 17123
Online Now [114]:
Visitors: 113
Today: 2295
Total: 99294194
Forums › The Car › 206 Problems › dead speedo
dead speedo
TieBreakGreen
PostPosted: Thu Dec 09, 2010 8:12 pm Up
Just got my 2000 Roland garros 1.6 and most urgent problem (when there's a bit less snow) is the speedo. Currently no speed reading at all, and odometer not moving either, although rev counter is still fine. car had a replacement speedo head fitted a few years ago after having the same problem and the new unit only has just under 7000 miles on, previous one failed at about the same mileage.
Haven't investigated at all yet so I'm hoping just a corroded connection or something (car's had very little use, hence mileage) but any suggestions or common fail points???
Andrew.
The Roland Garros: RIP
jonny_fulton03
PostPosted: Thu Dec 09, 2010 8:54 pm Up
my rev counter has just done the exact same thing!! all other dials are fine but the revs are dead! Sorry this doesnt help you. If you find a solution id love to know! Cheers Joni.
panason1c
PostPosted: Fri Dec 10, 2010 3:08 am Up
Might be the 'sender' unit, it's fitted to the gearbox, check the plug connection to it, or it might be the sender faulty.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Jayyy1989
PostPosted: Fri Dec 10, 2010 4:09 am Up
My rev counter didn't work when i bought my car, just got some new clocks off ebay and works like a charm Smile Pretty sure the soldering goes on them, ebay for some now clocks, double check if you have 1 or 2 plug connectors on the back though
Jay Kane
PostPosted: Fri Dec 10, 2010 4:13 am Up
My speedo and odometer were fixed last year. It was a broken wire at the big connector behind the front bumper. As the ECU wasn't getting road speed information it also meant the engine idled lower than before.
TieBreakGreen
PostPosted: Mon Jan 24, 2011 6:55 am Up
just getting round to this now, think it is the cluster rather than the sender (dammit) but if I'm trawling ebay does anyone know will any 2 plug petrol speedo do or do they differ for different engine sizes? 8v 1.6 speedos seem thin on the ground (and there seems to be pretty much zero chance of finding a replacement cream RG set)
