Online Now [94]:
Visitors: 93
Today: 64402
Total: 139073223
Forums › The Car › 206 Problems › 206 GTi Won't start
206 GTi Won't start
DanielzZz
PostPosted: Thu Dec 09, 2010 10:26 am Up
Hey,my name is Daniel and I'm helping a friend with a crashed 206 GTi.Here's the problem:
the car started successfully after 2 years of not being drivven,the engine was working very well,although the STOP light was working.Some messages appeared on the Board Computer,but I didn't read them,because they were in German,and I don't speak that language.
Now the car doesn't want to start,the Engine light stays on.
Also,do you know what resistances should I put on the front airbags,so the Airbag light turns off ? The Airbags are gone after the crash.
Also,my friend checked a pre-facelift 206 GTi and it had something like a restart button in the front(near to the left fender),but his doesn't have that button.Is it possible for it to be moved in other place ?
Thanks,and sorry for my post,I know I have a lot of mistakes,but I'm in a verry big hurry,and I will edit it later.
Cheers,Dan !
206 GTi,106 RallyE
Schumi
PostPosted: Thu Dec 09, 2010 11:27 am Up
If you have onboard computer your car is multiplexed. So you didnt have any fuel cut switch for crash. Did you disconnect battery for 5 minute. And reconnect. Is it cranking ? If its remove fuel line from fuel rail and check fuel is there and enought pressure (3 bar). And you can change language of onboard computer. Its same with adjusting clock. For airbag. First all of you have to reprog you stock airbag controller unit or change with brandnew one or unactivited unit from another car with same amount of airbag (2 or 4 airbag). After reprogramming of your unit you can measure ohm of unactivited airbag unit and solder same ohm resistance. Without reprogramming you cant turn off airbag light.
2005 206 RC RED
panason1c
PostPosted: Thu Dec 09, 2010 11:45 am Up
Airbag light?..............easy!........remove the bulb from the instrument cluster.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
panason1c
PostPosted: Thu Dec 09, 2010 11:47 am Up
Check the timing belt hasnt failed...........it might have given up after being static for 2 years.
BMW K1200RS
Schumi
PostPosted: Thu Dec 09, 2010 12:04 pm Up
Car is multiplexed. There is no bulbs. Its SMD LED's. It's have to desolder for remove. Also onboard computer show several errors about airbag.
2005 206 RC RED
DanielzZz
PostPosted: Thu Dec 09, 2010 5:28 pm Up
The problem is the car is my friend's property...but he doesn't speak English,and nobody wants to answer in those Bulgarian forums.Anyway - the engine was working perfectly fine,and all fluids were changed with brand new.Can you explain in detail how to change the language ? I will give a try of that 5 minute battery disconnection.I think the airbag does not need reprograming,because when I put the right resistance the car will think it has airbags.
So...is there any way to manually reset the ECU (I think the problem is there) ?
206 GTi,106 RallyE
DanielzZz
PostPosted: Fri Dec 10, 2010 5:02 am Up
Making progress...the 5 minute battery disconnection didn't work.
206 GTi,106 RallyE
