Latest: Andyblue64
Overall: 17123
Online Now [115]:
Visitors: 114
Today: 83497
Total: 98907500
Forums › The Car › 206 Problems › GTi 180 Slight Juddeering When setting off
180tomtom
PostPosted: Fri Dec 10, 2010 3:47 pm Up
I have just purchased a GTi 180, The car is absolutrly mint, no complaints what so ever.. apart from just one thing, wondering if it is a common fault.
When i set off from stationary there is quite a nasty judder, kind of like the engine mounts are loose type of a judder. Once you are mooving thou it completly goes away untill you stop and set off again.
Any thoughts??
"Purity is the Essence of Perfection"
koopa180
PostPosted: Fri Dec 10, 2010 4:01 pm Up
Yes, this is very common. I'll think you'll find everyone on here has, or had the same problem. I don't think it's anything to worry about though.
gpvecchi
You have to check engine support near cam belt. If that's good, probably you clutch is about to f..k up... It's not rare on GTI 180 (at around 60000 km)...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
kingdom200
PostPosted: Fri Dec 10, 2010 4:10 pm Up
its nothing to worry about very common problem so enjoy your 180 Very Happy
PUG1OFF Cat Cams/ ECU project
180tomtom
Milege is just over 57k.. i can tell the car has been very well looked after. There is just this judder as i say. i have had a 140 GTI before and i could of sworn it did the same thing.
kieron
PostPosted: Fri Dec 10, 2010 4:24 pm Up
mine judders too its commom as muck!
Account suspended
PostPosted: Fri Dec 10, 2010 4:30 pm Up
mine does this from cold and has every morning since iv had it and iv done 42k since i bought it and never had a problem stops doing it after half mile or so i wouldnt worry too much Very Happy
180tomtom
Just gets a little bit irritating, speically when you have passengers in car.. Bit of a perfectionist so will have to get it sorted out lol..
So i am looking for engine support at cambelt side... failing that it should be the clutch that needs replacing..??
206de
PostPosted: Fri Dec 10, 2010 4:37 pm Up
Most likely to be the clutch I had mine replaced about 4k miles ago on mine and the cold weather has brought a little judder ever so slightly in the mornings Sad
Must be a bad clutch design!! I would consider maybe uprating if you do decide to change the clutch as the judder will more than likely come back after a few thousand miles!
2005 Obsidian Black GTi 180 | Front -50mm Eibach Suspension | Rear Torsion Bar Lowered -30| SP Grille | Gloss Black Vortex Alloys
180tomtom
PostPosted: Fri Dec 10, 2010 4:43 pm Up
I don't know... poor french lol. They certainly know how to extract power from an engine. Just not for very long lol...
What sort of clutches would you reccomend me to be looking at ??
206de
PostPosted: Fri Dec 10, 2010 4:55 pm Up
Haven't looked into any alternative clutches mate but if I'd known my new one was gonna start showing signs of the juddering again so early on, I would have got another lol
180tomtom
PostPosted: Fri Dec 10, 2010 4:56 pm Up
Bit of a shame that really if it comes back so quickly. How much was the standered clutch?? did you fit yourself??
Antix
PostPosted: Fri Dec 10, 2010 4:58 pm Up
Custom - Red Stars
I had the juddering, most pronounced when you pull away at speed.
I had a new clutch fitted which solved it. The clutch was SAKS branded (German, as used in VW, Audi, Mercedes) and was a superb clutch, the biting point was very low which helped fast gearchanges Wink
180tomtom
PostPosted: Fri Dec 10, 2010 5:02 pm Up
How many miles have you got out the clutch so far Antix???? and has the juddering never returned??
Antix
PostPosted: Fri Dec 10, 2010 5:04 pm Up
Custom - Red Stars
Car was sold, it had the original clutch replaced at 65k miles.
New clutch had only done about 1000 miles when I sold it.
