Online Now [210]:
Visitors: 208
Members: 1
Today: 58115
Total: 155776375
Forums › The Car › 206 Talk › Kwik Fit for brake pads?
Forum Index › 206 Talk
Go to page Previous  1, 2
Lecktorious
PostPosted: Sat Dec 11, 2010 9:24 am Up
Trade Rating: +59
Or do it yourself, probably the quickest and cheapest option. It aint hard!
'98 Nile Blue 306 GTi 6
T_bandery
PostPosted: Sat Dec 11, 2010 9:36 am Up
DIY it dude, one of the easiest thing to do
and here is a how to guide
Bigbenj_08
PostPosted: Sat Dec 11, 2010 5:13 pm Up
Yea I spotted the guide Smile
Going to give these guys a call on monday instead.
www.europeanautoservices.co.uk/
Also going to get under the car and actually look at my brakes... maybe even visit a few motor factors if I need to.
What is the minimum thickness of pads for a 206?
Whats the best way to check what type of pads I need?
Looking on eurocarparts there are 2 different rear pads and 1 set of fronts.
Looking at the fitment guide, both of the rears are the same fitment.
Fronts listed are Bosch, both rears are Bendix.
Does that sound correct?
BTW, many many thanks for all the help guys Smile I really should start making more appearances on here!
EDIT: Also, I believe I should check the condition of my disks at the same time, is there an easy way to check the disk thickness?
Thanks,
Ben
Aegean Blue 1.6 16v Sport
PostPosted: Sat Dec 11, 2010 5:36 pm Up
You need pads to suit 266x22mm discs on the front, they are also fitted to later GTi's, HDi's and 1.6 16v. Also to suit Bosch callipers.
The minimum thickness of discs is 20mm. Just use a ruler to measure them.
The rear discs have a minimum thickness of 6mm. They should be 247x8mm
Front pads are:-
131mm long
47.5mm high
18 mm thick
Rear pads are:-
105mm long
54.8mm high
11mm thick
Bigbenj_08
PostPosted: Sat Dec 11, 2010 5:48 pm Up
Lee you're a legend.
I've put my car reg into euro car parts and its come up with the correct rear brakes that match your dimensions but not the front.
Done a manual search and can't find the fronts either Sad
Can the pad size vary slightly depending on the make?
EBC I have found:
Front-
130x50x17
Rear-
106x56x11
Thats seems fairly close lol. Does that sound about right?
PostPosted: Sat Dec 11, 2010 5:59 pm Up
Front Discs - www.eurocarparts.com/e...c86e9&BDIS
Front Pads - www.eurocarparts.com/e...16c43&BKPA
Rear Discs - www.eurocarparts.com/e...8b1fc&BDIS
Rear Pads - www.eurocarparts.com/e...6f8c7&BKPA
I just clicked on the first ones, by no means am I recommending those brands.
Ferodo pads with Brembo discs everytime
Bigbenj_08
PostPosted: Sat Dec 11, 2010 6:10 pm Up
Thanks again Lee.
Thats probably the quality of pads/disk that is on there now so until i have funds to upgrade then they should do fine Smile
Bigbenj_08
PostPosted: Sun Dec 12, 2010 9:49 am Up
Well... just been halfords...
Bought a trolley jack, some copper grease and I'm now buying some EBC Ultimax pads for front and rear Smile
So next weekend i'll be changing the pads myself.
Disks are perfectly fine, almost no wear on the rear and about 1mm on the fronts.
think i'm going to continue the trend of doing stuff myself and finally get the air filter changed too lol. Found the K+N standard replacement fairly cheap so i'll give that a go Smile
Oh and I even took the car for a quick clean Laughing
Thanks again everyone!
Page 2 of 2
