Posted: Sun Dec 12, 2010 11:45 am |
MrBSI wrote: |
You tried spraying the bonnet sensor with some WD40?
Its the small black switch attached to the catch.
Check it also hasnt fallen off |
just got home its dark now will take a look tomorrow - cheers
Posted: Tue Dec 14, 2010 4:56 pm |
MrBSI wrote: |
i cant see a small black switch on catch to be honest
Posted: Tue Dec 14, 2010 5:18 pm |
| Former owner of a 1.4 HDi for six years | |
Posted: Tue Jun 21, 2011 3:18 pm |
Hi, Did you fix the problem? I also have an alarm that wont function,
the Boot/Bonnet sensors are situated in the correct place
the wiring seems to be ok to the Textron control box (Pillars are connected)
Ive tried arming it with the windows down and running my hand across the sensors, nothing happens, not even the lights flash..
the only weird thing is when i lock and unlock the car i get a strange noise as if someone *excuse this* farted.
How can i get the blinkin thing to work...
anyones help much appreciated.
Posted: Tue Jun 21, 2011 3:26 pm |
Lock the car with the fob, then manually unlock it with the key
Posted: Tue Jun 21, 2011 3:57 pm |
hi, cheers for the quick reply, tried that, no luck :/ it just unlocks normally
Posted: Tue Jun 21, 2011 3:59 pm |
Your alarm isn't even activating then. Possibly a problem with the control unit
Posted: Tue Jun 21, 2011 4:04 pm |
ive taken the thing out, disconnected it, reconnected it, still nothing, the fuse is ok also, yeah you could be right, thank you.
now where to buy one.. haha
Posted: Wed Jun 22, 2011 3:51 am |
wpday07 wrote: |
Your alarm is trying to tell you one of the doors / boot / bonnet isnt shut correctly & that means the system wont arm.
Posted: Wed Jun 22, 2011 4:10 am |
so the sensors are broken?
Posted: Wed Jun 22, 2011 4:12 am |
Your alarm is trying to tell you one of the doors / boot / bonnet isnt shut correctly.
You need to check which sensor is stopping the alarm system arming.
Posted: Thu Jun 23, 2011 7:21 am |
thank you
Posted: Thu Jun 23, 2011 9:00 am |
Lee wrote: |
Are all the doors actually locking when you lock the car?
I've got a dicky drivers lock which doesn't always lock and that causes my alarm to not activate. |
Now I know which door to try. Thanks Lee
Posted: Fri Jun 24, 2011 6:25 am |
it seems that all of the sensors are ok, its a 2003 model so it shows up if the door is open etc. It must be the control box.. :/
Posted: Fri Jun 24, 2011 7:59 am |
wpday07 wrote: |
it seems that all of the sensors are ok, its a 2003 model so it shows up if the door is open etc. It must be the control box.. :/ |
Needs scanning with Peugeot Planet.
