Latest: tebas93089
Overall: 17179
Online Now [297]:
Visitors: 296
Today: 56999
Total: 137908212
Forums › The Car › 206 Problems › 1.4 HDI power loss
1.4 HDI power loss
D4VE
PostPosted: Sun Dec 12, 2010 9:18 am Up
Hi,
I have just bought a 1.4 HDI but is really slow. You can hear the turbo spooling but still down on power.
Any ideas?
Dave
troy
PostPosted: Sun Dec 12, 2010 9:22 am Up
diagnostic check, could be any sensor, actuator, turbo, could be anything so diagnostic is a good place to start
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
D4VE
PostPosted: Sun Dec 12, 2010 9:43 am Up
I'll book it in tomorrow Crying or Very sad
Thanks for the reply
harvey
PostPosted: Sun Dec 12, 2010 12:47 pm Up
and let us know the outcome thanks Smile
harv
D4VE
PostPosted: Sun Dec 12, 2010 1:40 pm Up
I'll keep you posted Rolling Eyes
mjsroofing
PostPosted: Sun Dec 12, 2010 2:53 pm Up
check the air intake pipes, one might of split or come off
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
D4VE
PostPosted: Mon Dec 13, 2010 3:57 pm Up
Hi,
Just to keep you updated I had the car on a friends diagnostics scanner and all clear Confused
Its off to a peugeot specialist tomorrow so hope this solves the problem.
Bigbenj_08
PostPosted: Mon Dec 13, 2010 4:01 pm Up
define really slow?
Aegean Blue 1.6 16v Sport
D4VE
PostPosted: Mon Dec 13, 2010 4:09 pm Up
On a steep hill it struggles to get above 30 and can't get past second gear as it dies in thrd. On the motorway on a flat section its struggling to keep 70.
Feels to hit a flat spot at about 2500 - 3000 revs
mjsroofing
PostPosted: Mon Dec 13, 2010 4:14 pm Up
did you check pipes????
vacum pipe can cause this ??
Mark
D4VE
PostPosted: Mon Dec 13, 2010 4:18 pm Up
I checked the air intake pipe and the was a joint loose so sorted that but will check the vaccum pipe tomorrow
PostPosted: Mon Dec 13, 2010 4:19 pm Up
Was it a proper diagnostic reader or a cheap s***ty one?
D4VE
PostPosted: Mon Dec 13, 2010 4:23 pm Up
It looked like it was a cheap s***ty one!
D4VE
PostPosted: Wed Dec 15, 2010 6:33 am Up
Hi Gents,
Just an update on the power loss problems. The code it brought up apparently relates to a blocked exhaust, more likely to be a collapsed catalyst.
Will be taking it off one evening this week to attack it! One its all cleared out I should be back up and running!
I'll keep you posted.
panason1c
PostPosted: Wed Dec 15, 2010 7:03 am Up
Check out the exhaust first, otherwise it sounds like the 'maf' is bad, remove it from the airbox and try spraying it with electrical contact cleaner. (dont attempt to clean it with anything else!)
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
