Latest: tc.206
Overall: 17147
Online Now [169]:
Visitors: 168
Today: 20340
Total: 116475351
Forums › The Car › 206 Talk › How to Bleed Engine Coolant
Adam
PostPosted: Thu Apr 22, 2010 2:36 pm Up
How do I bleed a peugeot 206 (54 plate) engine coolant, I want to remove all the coolant and top it up with new fluid.
Adam
Squeaker
PostPosted: Thu Apr 22, 2010 2:43 pm Up
So do i Smile
Adam what engine is yours?
Adam
PostPosted: Thu Apr 22, 2010 2:45 pm Up
Squeaker wrote:
So do i Smile
1.4/petrol
Adam
PostPosted: Thu Apr 22, 2010 2:52 pm Up
www.psa-peugeot.info/P...gg0rk3.htm
Squeaker
PostPosted: Thu Apr 22, 2010 3:06 pm Up
Some of the pictures dont work for me?
(Flukey Free Kick BTW Wink )
Adam
PostPosted: Thu Apr 22, 2010 3:07 pm Up
Yea, same here.
Adam
PostPosted: Thu Apr 22, 2010 3:16 pm Up
For a start, awesome freekick Razz
B1GG0RK1 - 206 TU ENGINE DW8 ENGINE
DRAINING - FILLING - BLEEDING COOLING SYSTEM
1 - SPECIAL TOOLS
[1] filling cylinder (-).0173/2 .
2 - DRAINING
TU ENGINE
DW8 ENGINE
ALL MODELS
Carefully remove the expansion chamber cap .
Unscrew the radiator drain plug (1) .
NOTE : fit a pipe to the outlet to allow clean drainage of the system .
TU ENGINE
DW8 ENGINE
ALL MODELS
Open the bleed screws (2) .
DW8 ENGINE
Drain the engine by removing the plug (3) .
ALL MODELS
3 - FILLING AND BLEEDING THE SYSTEM
Before any re-filling operation, flush the cooling circuit with clean water .
WARNING : check the cooling system for leaks .
DW8 ENGINE
TU ENGINE
ALL MODELS
Fit the filling cylinder [1] to the filler opening .
Open all the bleed screws .
Fill the circuit slowly with coolant .
Close the bleed screws in the order in which the liquid flows without bubbles .
The filling cylinder must be filled to the 1 litre mark to bleed the heater matrix correctly .
Start the engine .
Maintain the engine speed at 1500 to 2000 rpm until the end of the second cooling cycle (fan(s) starting then stopping) keeping the filling cylinder filled to the 1 litre mark .
Stop the engine .
Remove the filling cylinder [1] .
Immediately tighten the plug on the expansion chamber .
If necessary fill up to the level of the maximum mark (Engine cold) .
Squeaker
PostPosted: Thu Apr 22, 2010 3:22 pm Up
Flukey...
Mine isn't shown Confused
PostPosted: Thu Apr 22, 2010 3:25 pm Up
Just face it, your going down Razz
Yeah I know, don't have a guide for the 1.6 Sad
206-GTi
PostPosted: Thu Apr 22, 2010 3:30 pm Up
There is a tap at the bottom of the radiator. You can bleed it all from there.
Adding new coolant is a different story. of course you want to pour it in the resovor. Just make sure you bleed all air out of the system.
I used a Milkshake bottle with the bottom cut off fixed to the resovor to put the new stuff in. Will need to run the car and get the fan to kick in twice. You will notice the coolant in the bottle (milkshake in my case) suddenly disapear after the fan kicks in (Thermostat opens and allows it to run through I belive).
GTi - Black - 2002
Shaq22
PostPosted: Sun Jul 25, 2010 11:15 pm Up
is it possible someone will fix the images?
EDIT: nvm, found it somewhere else!
James28
PostPosted: Mon Dec 13, 2010 9:45 am Up
I've got a 2002 1.4 8v 206. does anyone know where I can get a guide to change the coolant on my car? Thanks
James
Norvvv
PostPosted: Sun May 15, 2011 7:15 am Up
Mega bump. Anyone got this with pictures?
2001 1.4lx
PrePlexed 5 door.
stevedude
PostPosted: Sun May 15, 2011 7:19 am Up
none showed up for me
Happydays
Norvvv
PostPosted: Sun May 15, 2011 8:36 am Up
BUMPPP! i know i only posted an hour ago but i realllyyy want to get this done today! :/
2001 1.4lx
PrePlexed 5 door.
