Latest: ArtistKS
Overall: 17145
Online Now [212]:
Visitors: 210
Members: 1
Today: 21556
Total: 116114722
Forums › The Car › 206 Problems › A puzzel / problem (moving an engine)
Antknee
PostPosted: Mon Dec 13, 2010 12:18 pm Up
take it to pieces and carry it bit by bit? Razz
PostPosted: Mon Dec 13, 2010 12:20 pm Up
nick180 wrote:
Cut the bottom slamp panel so the engine can come straight threw the front of the car. Put engine on wooden board put a hole in wooden board tie a piece of rope threw it and drag down the drive with another car. Just an idea.
Cutting the slam pannel is the plan, but I don't want to drag it though the gravel as the engine may topple off, or the pallet will get dug into the gravel.
PostPosted: Mon Dec 13, 2010 12:21 pm Up
You can if you like. Then reassemble at the top of the drive.
PostPosted: Mon Dec 13, 2010 12:22 pm Up
Tie the engine to the pallet so it doesn't move, then tie some rope to the car and the pallet, and rag it up the drive Laughing
Done that many of times, for moving other stuff Laughing
NICKST
PostPosted: Mon Dec 13, 2010 12:24 pm Up
You need a flat piece off wood to drag it down the drive then put it on a pallet at the bottom of the drive.
Dillon
PostPosted: Mon Dec 13, 2010 12:33 pm Up
Staff - Dillon
What He Said
Ape
PostPosted: Mon Dec 13, 2010 12:34 pm Up
Explosives. Any problem is solved with explosives
Iain
PostPosted: Mon Dec 13, 2010 1:35 pm Up
I think this is a job for Wally Wallington
www.youtube.com/watch?v=oK1Rzch89Dw
He moves heavy things. That's about it.
Our snow > Your snow
bellevuespares
PostPosted: Mon Dec 13, 2010 1:57 pm Up
Id simply cut away the front panels, lay down a 8x4 sheet of ply, slide engine onto it, pull from under the car by the board, then lay your pallet next to engine and lift it on, strap it on pallet, and use the 8x4 as the floor to tackle the gravel, have a 8x4 sheet of ply ready at the cattle grid and the jobs a gooden:)
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
mjsroofing
PostPosted: Tue Dec 14, 2010 5:34 pm Up
jack car up as far as you can then use blocks of wood on jacks to get it even higher, drag the engine out from underneth and man handle it down the drive, i've even carried an engine before now. roll your sleves up boy........
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
5napey
PostPosted: Tue Dec 14, 2010 6:12 pm Up
Lee wrote:
Don't you know anyone with a lorry with a hiab? Just get them to pick the car up. Surely there's someone who lives near you thats delivers things or does bangers.
+1 this is simple enough to work.
-Snapey- 2002 Diablo Red 1.4 GLX -
i am NOT drunk - i am pothole dodging ^^
skard
PostPosted: Tue Dec 14, 2010 6:14 pm Up
last time i did it we got a scaffolding bar put onto a sling (around the engine) and just lifted it up and over with three of us.
mattievrs
PostPosted: Tue Dec 14, 2010 6:28 pm Up
cut the slam panel out then roll the car backwards.Get 3 mates to lift it into the boot of the vrs then drive it down the bottom of your drive.Then get 3 mates to lift it out and put it on the pallet.
NO LONGER ACTIVE ON THE FORUM
PostPosted: Tue Dec 14, 2010 6:45 pm Up
We did this in the end, just took a while but its now on a pallet Smile
PostPosted: Wed Dec 15, 2010 2:03 pm Up
Get some muscle and lift it onto a wheel barrow?
Page 2 of 3
