Latest: ArtistKS
Overall: 17145
Online Now [65]:
Visitors: 64
Today: 16369
Total: 115916257
Forums › The Car › 206 Problems › 206 1.4 idle speed to high
russman
PostPosted: Mon Dec 13, 2010 5:06 pm Up
Hi everyone hopfully someone can help, my 206 1.4 has been in the garage for some time and trying to sort out the high idleing speed i am talking about 14-1500rpm (idle). They are saying i need a new ECU possibly.
Anyone have any further ideas... or slightly cheeper ideas
Does anyone know if the Idle Speed Control Valve will do anything...
Cheers
Thanks,\r\nRussell
brad-morris
PostPosted: Mon Dec 13, 2010 5:08 pm Up
thats not very high for idle, but if it bothers you too much you can try cleaning the ICV
PostPosted: Mon Dec 13, 2010 5:11 pm Up
idle is 850rpm +/- 100rpm.
Try cleaning/changing the ICV. Also check the throttle position sensor
brad-morris
PostPosted: Mon Dec 13, 2010 5:18 pm Up
I thought the idle was higher than that mines 1100rpm
Ash
PostPosted: Mon Dec 13, 2010 5:22 pm Up
Mine's similar except when cold.
Spanerman
PostPosted: Mon Dec 13, 2010 5:23 pm Up
Check the throttle body closes propperly too Wink
Hello
russman
PostPosted: Mon Dec 13, 2010 5:37 pm Up
Cheers people i'll tell them that yea it used to tick over at about 800 - 1000rpm (tops)
Thanks,\r\nRussell
mjsroofing
PostPosted: Tue Dec 14, 2010 5:28 pm Up
about 900 is good, clean throttle body
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
russman
PostPosted: Thu Dec 23, 2010 9:00 am Up
tried cleaning out the throttle body and cleaning and replaceing the idle'ing positioning sensor but still no luck still haveing problems starting and the high tick over Sad
really wierd even my garage is getting confused. nothing is coming up on the diagnostics either, any more help, could it be the ECU at fault does anyone think....
any help would be apprieciated,
Thanks,
Russel
Thanks,\r\nRussell
