Latest: tc.206
Overall: 17147
Online Now [199]:
Visitors: 198
Today: 12687
Total: 116509250
Forums › The Car › 206 Problems › (02) 206 GTi 137...totally dead...nothing happening!!!
Newty
PostPosted: Mon Dec 13, 2010 4:13 pm Up
Hi there...
I have had this 206 for a couple of months, just a wee runaround car so doesn't get driven too much.
Anyway, my missus took the car to work on Thursday and it was fine. She went to open it Saturday morning, and the key remote wouldn't work. So she opened it manually and the alarm went off, as it should!
Anyway, when you now put the key in the ignition and turn it, nothing happens at all... not even a dashboard light, not a click, nothing!
I have had the battery out for a charge, had another car 'jump' it but nothing what so ever, as said, not even a dashboard light.
Is this an immobiliser problem? Or something simple which I am missing?
Thanks.
Hmmm...what can I do??!!!
PostPosted: Mon Dec 13, 2010 4:15 pm Up
Check the earth straps.
Mr_Cellexe
PostPosted: Mon Dec 13, 2010 4:48 pm Up
would be my best guess.
M60SHW
PostPosted: Mon Dec 13, 2010 5:49 pm Up
i had the same problem and it was the gearbox earth srap haha
Team, ST
Team, Gti 138 track slag
kieron
PostPosted: Tue Dec 14, 2010 4:56 am Up
if the immob was at fault you still get lights on the dash it would turn but just woulndnt fire
as above try the earth straps failing that try relays and fuses
do you have power to anything else?
Account suspended
PostPosted: Tue Dec 14, 2010 11:06 am Up
Did the alarm shut up when the ignition was turned on?
If it did then the immobiliser is working fine Wink
Newty
PostPosted: Tue Dec 14, 2010 2:29 pm Up
Ai, alarm stopped when key was turned in the ignition.
So earth strap it is, hopefully. Sounds good, I'll just have a quick Google of the earth strap!
By the way, everything is dead, not a single light o function is working!
Thanks peeps.
kieron
PostPosted: Tue Dec 14, 2010 2:38 pm Up
got to be a earth if you have nothing on
Account suspended
Newty
PostPosted: Tue Dec 14, 2010 3:12 pm Up
Ok. Just had a look under the bonnet with me wee torch. The earth on top of the gearbox is intact and secure. Anywhere else I should look? Had a route around but nothing caught my eye other thean the headlight earths.
Only had the car a couple of month, how bizarre that a little earth cable can cause a whole car to shut down!!!
Please point me in the right direction of this dodgy earth!
Thanks.
PostPosted: Tue Dec 14, 2010 3:57 pm Up
So you can see the earth strap where it attaches to the gearbox and inner wing?
Newty
PostPosted: Wed Dec 15, 2010 2:28 pm Up
I can see an earth cable on top of what I believe to be the top of the gearbox, I couldn't see another though. But I guess you have just given the location of it away to me!!! Do I need to get underneath to see the wing one?
Ta.
PostPosted: Wed Dec 15, 2010 2:48 pm Up
You can see the earth cable at the left hand side of the picture just to the left of the 3 brake pipes. The earth cable also has a white label on it.
