Latest: S2cgm
Overall: 17178
Online Now [155]:
Visitors: 154
Today: 61041
Total: 135870613
Forums › The Car › 206 Problems › Puddle!
Puddle!
Go to page Previous  1, 2
Werdnal
PostPosted: Tue Dec 14, 2010 5:06 pm Up
I was going to suggest door membranes too. I bought a Golf once and first time I put the hose on to wash it, it literally filled up both front footwells. Realised now when we went to see it, and then went back to collect, the chap had it in his garage! Both door membranes were completely shredded. Trouble is people take them off to work on the door, speakers etc, then think they aren't important and don't stick them back. We made replacements out of thick clear polythene and used spray-on "carpet" glue to stick them on. Solved the problem for us.
Also had a heater matrix go once. You'd know if it was this because if you were losing enough to cause a puddle, you'd be having to top up water in your coolant header tank. I also had steam coming out of my dashboard - rather Shocked when you initially mistake it for smoke!
Lewis1592
PostPosted: Wed Dec 15, 2010 8:25 am Up
Haha love the steam thing!
Havnt had to add any coolant at all, makes me want to check the door membrane then!
So do I simply close the door with someone inside and pour water at the base of the window...or do I open the door, pour the water and check for it pouring from the bottom of the door?
Thanks for the great reply a btw Smile
2001, 206 1.4 lx first car Very Happy
continentalgt
PostPosted: Wed Dec 15, 2010 9:09 am Up
Open the door wide open and stand facing the inside of the door and reach over the window frame to pour the water while viewing the bottom and sides of the door card to see if any comes out. Oh yes watch your feet because they might get wet!
copey
PostPosted: Wed Dec 15, 2010 9:43 am Up
tomd0801754 wrote:
Surely it's easier to jack the car and look under it than rip carpets up.
My idea would be to check around the reading light, feel if there is a damp patch around it, mine likes to leak through there every now and then lol.
yeh think tis quite common on pugs, throught the aeiral, assuming its on front, myold 106, dads 206 and friends 306 all do it
02 2.0 hdi d turbo
Page 2 of 2
