Online Now [148]:
Visitors: 147
Today: 68664
Total: 117318545
Forums › The Car › 206 Problems › Milky/muddy engine oil please help!
Go to page 1, 2, 3  Next
jamie_206
PostPosted: Wed Dec 15, 2010 9:41 am Up
Hi
I cant check my oil as the dipstick is always covered in thin mud like oil . Which I thought was due to the dip stick seal breaking . Today I opened the oil cap and inside the cap it was full of yellow/white sludge also there was a little steam coming out of the oil filler hole . What does this mean? Ive heard this happens when the head gasket goes but my cars running fine.
copey
PostPosted: Wed Dec 15, 2010 9:42 am Up
my old 106 used to start fine and run fine with a blown gasket aswell
02 2.0 hdi d turbo
yes, head gasket blow.
you can also check if you got less coolant and the spark plug as well
Danw_VVT
PostPosted: Wed Dec 15, 2010 9:49 am Up
as said.... head gasket.
PostPosted: Wed Dec 15, 2010 9:52 am Up
Is it always there or just when the engine is still cold from a short journey?
jamie_206
PostPosted: Wed Dec 15, 2010 10:11 am Up
FFS ! ! . . . Nah its like this all the time . Just serviced it last month the plugs were white so running lean and hot . Its started getting hotter than normal . The coolant is a very dark green . And just noticed when idling the exhaust quietly pops now and again missfiring maybe?
So what should I do . Even though it seems fine I guess it would be foolish to ignore it?
PostPosted: Wed Dec 15, 2010 10:17 am Up
i would get it fixed soon. new gasket+skim head
jamie_206
PostPosted: Wed Dec 15, 2010 10:34 am Up
Ok thanks for the fast replys guys !
PostPosted: Wed Dec 15, 2010 10:45 am Up
Don't forget the new timing belt kit while its apart Wink
mattievrs
PostPosted: Wed Dec 15, 2010 11:33 am Up
Is it losing coolant mate?
NO LONGER ACTIVE ON THE FORUM
jamie_206
PostPosted: Wed Dec 15, 2010 11:35 am Up
Just been quoted £600 for new gasket preasure testing and new timing belt and water pump . . How does that sound?
mattievrs
PostPosted: Wed Dec 15, 2010 11:40 am Up
matcarlin24
PostPosted: Wed Dec 15, 2010 11:41 am Up
Is that with the head being skimmed aswell?
206 Moonstone 1.4 8v Wink
copey
PostPosted: Wed Dec 15, 2010 11:49 am Up
if i remember rightly, on my 106, it cost me around £350 thats with it being skimmed and al that to....how ever, i have no idea if there's a difference how much more labour is involved from engine to engine
02 2.0 hdi d turbo
jamie_206
PostPosted: Wed Dec 15, 2010 11:50 am Up
It dosent seem to be losing coolant but its hard to tell with the usless levels on the header .
And yea thats with it being skimmed.
Page 1 of 3
