Posted: Wed Dec 15, 2010 11:18 am |
Looking a how to guide for replacing the rubber gasket that goes between the rocker and head of the engine, its for a 1.4 8v kfw engine
Posted: Wed Dec 15, 2010 11:36 am |
Top tip.
Make sure you tighten the securing bolts to the correct torque, if you over tighten them you will bend the rocker cover & it will leak even with the new gasket
Posted: Wed Dec 15, 2010 2:12 pm |
| MrBSI wrote: |
Top tip.
Make sure you tighten the securing bolts to the correct torque, if you over tighten them you will bend the rocker cover & it will leak even with the new gasket  |
Dont supose you know the torque values?
Posted: Thu Dec 16, 2010 8:38 pm |
| chrisd wrote: |
| MrBSI wrote: |
Top tip.
Dont supose you know the torque values? |
Any ideas people?
Posted: Sat Dec 18, 2010 9:34 am |
so no1 has a clue then? some use this place is
