Latest: S2cgm
Overall: 17178
Online Now [470]:
Visitors: 469
Today: 11477
Total: 135906725
Forums › The Car › 206 Problems › MORE & MORE & MORE problems
LilLew
PostPosted: Thu Dec 16, 2010 6:15 am Up
Hey all me yet again
I have had my rear driver side abs sensor replaced by the garge that has done my radius arm bearing
but my ESP/ASR not functioning & abs fault have not gone away connect her up to the good old computer but there is nothing on the ECU to help me diagnose can any body on here help tryed clearing all of the codes
so far
I have clean up all of the abs sensors and checked the condition of the abs rings all look fine no cracks or wear
2003 Pug 206 2.0 GTI 180
panason1c
PostPosted: Thu Dec 16, 2010 6:17 am Up
Try a battery disconnection/reconnection (bsi reset)
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Big_Rich180
PostPosted: Thu Dec 16, 2010 6:18 am Up
so far
Have you taken it for a decent drive so it has time to read the sensor?
Mines in today having a rear sensor Laughing 3rd ABS fault in 2 years Laughing
LilLew
PostPosted: Thu Dec 16, 2010 6:43 am Up
yep i have driven it for around a week hoping it would fix itself and i have done the BSI reset still to no luck
Big_Rich180
PostPosted: Thu Dec 16, 2010 6:45 am Up
Sounds like you may need a trip to pug then, very strange that there is no fault showing.
panason1c
PostPosted: Thu Dec 16, 2010 6:46 am Up
Might be something as simple as the ABS main fuse gone?
BMW K1200RS
Big_Rich180
PostPosted: Thu Dec 16, 2010 6:49 am Up
Would that not flag a fault on the ECU?
LilLew
PostPosted: Thu Dec 16, 2010 6:58 am Up
personally from my experince abs does not show up but i would of thought the ESP and ASR would of unless the abs and ESP / ASR are linked in some way
Big_Rich180
PostPosted: Thu Dec 16, 2010 7:01 am Up
They are linked, they both run off the ABS rings and sensors.
qwert
PostPosted: Thu Dec 16, 2010 7:04 am Up
What are you using to scan the codes? Cheap affordable code readers will only scan emission based codes, not ABS.
brum brum
LilLew
PostPosted: Thu Dec 16, 2010 7:09 am Up
i am using my dads laptop and diag software from the garage
panason1c
PostPosted: Thu Dec 16, 2010 7:18 am Up
It would help with the full story.......... ie..did the abs work BEFORE the new radius arm and sensor was fitted?, and if it did, why hasnt the garage that fitted the new radius arm and sensor sorted the problem?
BMW K1200RS
LilLew
PostPosted: Thu Dec 16, 2010 8:06 am Up
yes i had no faults before and after i got it back from the garage then about 3days later they started playing up
panason1c
PostPosted: Thu Dec 16, 2010 8:25 am Up
In that case i'd be looking again at the new sensor that was fitted..........check it is in its correct position and the 'gap' between the sensor and ring is correct, if the sensor is fitted too far from the ring it will not 'pickup' and disable the abs system along with esp and asr as they are all linked and work in conjunction with one another (compare the gap with that of the sensor on the other wheel)
BMW K1200RS
LilLew
PostPosted: Thu Dec 16, 2010 8:55 am Up
ill have another look when i get back home and ill double check all of the rings as well
