Posted: Fri Dec 17, 2010 2:29 am |
depends how much you look after it?
Posted: Fri Dec 17, 2010 3:45 am |
15k miles oil change intervals aren't ideal. I'd do 10k miles on a petrol at most.
Posted: Fri Dec 17, 2010 5:29 am |
these engine bullet proof, head gasket leak oil from the cambelt side but thats about it, clutch should do around 120k, thrust bearing are comman though, , clutch is only £80 though, light service every 5k ( just oil and filter) hoover your air filter, full service every 10k, plugs, oil, oil filter, fuel filter, air filter. the engine should exceed 150k this way.
if you were local i'd do it for you cheap
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Fri Dec 17, 2010 6:11 am |
I've spent a fair amount on consumables on my 1.4 HDi this year, but have carried out the work myself and I'm not a trained mechanic.
It's now completed 134K miles and, (touch wood), is running very well with no issues.
As long as you like the car and can afford it, have ALL the known faults rectified. Better the devil you know and all that .......
Posted: Fri Dec 17, 2010 6:13 am |
our 1.4 hdi is on 156k sound nice drives well does 50mpg
| Mark
Posted: Fri Dec 17, 2010 6:18 am |
Diesels tend to live longer.
Horrid things.
Posted: Fri Dec 17, 2010 6:19 am |
I went thew the same situation as you pal i bit the bullet as the car were spending most of its days in the garage getting fixed so i bought a new car might be a idea for you aswell just look at how much you could save, i have a 1.8 now and its chepper to insure than my old 1.4 206.
Posted: Fri Dec 17, 2010 6:25 am |
| Mark
Posted: Fri Dec 17, 2010 6:41 am |
I was thinking of asking the same question, mine's a 2000 x-reg 2.0D hdi glx blah blah but it's done over 127,000 miles =P and it still runs like a peach =) (touchwood) it's also in pretty good shape apart from stone chips on the bonnett =(
| 2002 1.6 5dr Black Edition. | |
Posted: Fri Dec 17, 2010 7:01 am |
If you look after any car well enough then they will last many many years!!! All the items you've stated are all wear and tear. But £800, better get other quotes
| Hi Mikey
Posted: Fri Dec 17, 2010 7:10 am |
cars can last forever, i've a ols 406 1.9 td on 250k still driving nice, ans a vectra gsi 2.5 v6 on 290k and still sounding and driving nice
| Mark
Posted: Fri Dec 17, 2010 9:23 am |
I just got rid of my 206 last week... 62k miles. The expected service bill with new clutch, dodgy overheating problem fix and wishbones was probably going to be 2/3s value of the car.
It was more economic to buy a 2yr old car and only have to pay for the service items.
Posted: Sat Dec 18, 2010 1:09 pm |
Decided to get rid. Lots of problems, garage nervous about gearbox lasting much longer.
Anyone in Sheffield area want to make me an offer to take away for parts?!!
Posted: Sat Dec 18, 2010 1:14 pm |
if it passed the mot just use it for another year to get your millage out of it then sell it.
| Mark
Posted: Sat Dec 18, 2010 1:31 pm |
It wont go through an MOt. Last one was Sept, things failed since then.
