Online Now [311]:
Visitors: 309
Members: 1
Today: 77366
Total: 156313778
Forums › The Car › 206 Problems › temperature sender sensor
johnk
PostPosted: Fri Dec 17, 2010 6:01 pm Up
As title, since i changed to a gti engine my temperature gauge doesnt work, just thinking it could be the sensor that tells the gauge, anyone know where it is on the gti? anyhelp appreciated.
Old info post count 1500
macj
PostPosted: Sat Dec 18, 2010 4:19 am Up
Thermostat housing.... green with plug on it right hand side of cylinder head
jimbo2470
PostPosted: Sat Dec 18, 2010 8:18 am Up
i thought green was for the management system? blue is usually for the temp gauge..
Gotta love french....
PostPosted: Sat Dec 18, 2010 8:24 am Up
Water temp gauge is bottom of rev counter on the GTI clock set.
I take it that's the gauge you dont have working at the moment?
macj
temp gauge gets its signal via the maneagment but I may be mistaken
jimbo2470
PostPosted: Sat Dec 18, 2010 8:29 am Up
i may be mistaken too, i dont know if the gtis are different, but my 1.4 had a gauge issue, which was the blue sensor..
johnk
PostPosted: Sat Dec 18, 2010 8:36 am Up
that and the temperature gauge on the right, when i first start the car the gauge on the right goes up to the top then back down a few times with a light next to it coming on then just sits on the bottom
PostPosted: Sat Dec 18, 2010 8:39 am Up
Gauge on right is oil temp.
Non plexed or plexed car?
Right type of gauges for the wiring system?
macj
PostPosted: Sat Dec 18, 2010 8:58 am Up
When it goes to the top it is telling you the oil level in sump... then it tells you oil temp after a few seconds... should register a reading after engine warms up.... sensor for that is in the sump on the left-hand rear as you look from the front of the car
johnk
PostPosted: Sat Dec 18, 2010 9:32 am Up
its pre-plexed, was a 1.4 8v now has 2.0 16v gti engine, hmm could be a wiring issue then
PostPosted: Sat Dec 18, 2010 10:00 am Up
Green sensor is the coolant temp sensor.
johnk
PostPosted: Sat Dec 18, 2010 11:26 am Up
cheers will give it a change see if it makes a difference, should be able to pick one up at my local peugeot parts.
johnk
PostPosted: Wed Dec 29, 2010 11:11 am Up
a bit more on this, went out to the car which hasnt been running since last night so its cold, straight away the water temperature goes to red and stays there and the stop light starts flashing and the fan kicks in, is this just a dodgy sensor? after driving for a minute or 2 the gauge goes to zero and doesnt move even after the cars warmed up and the stop light goes out. anyone got a peugeot part number and price for it?.
the cars a 2001 1.4lx but now has a gti 138 engine if it makes any difference?, not sure if the 1.4 had an oil temperature or if it was just water temp so might explain why the oil temp gauge doesnt work as it probably doesnt have the interior wiring for it.
Cheers for the help so far.
PostPosted: Wed Dec 29, 2010 11:55 am Up
Are the hoses to the radiator hot?
johnk
PostPosted: Wed Dec 29, 2010 1:00 pm Up
Yeah just took the car for a drive for a few miles to warm it up got back and the hose from the radiator to where the sensor is was hot, typically when i tried to video starting the car to show the water temp gauge and stop sign it didnt happen!, temp gauge still didnt move once it was warmed up though.
