Forums › The Car › 206 Talk › I know its a 1.6 but which 1.6 is it? |
Posted: Sat Dec 18, 2010 9:59 am |
Good evening all, just a quick and probably easy question to answer. How do I know what model engine is in my 206?
Posted: Sat Dec 18, 2010 10:04 am |
Does it have disc brakes on the rear?
Posted: Sat Dec 18, 2010 10:14 am |
Its a TU5JP seeing as its a XS model.
That's the 8 valve 1.6 lump
Posted: Sat Dec 18, 2010 10:23 am |
MrBSI you seem to be be a very good guy to know
