Online Now [310]:
Visitors: 309
Today: 120930
Total: 154930255
Forums › The Car › 206 Problems › Sighh, so much for that!
Go to page Previous  1, 2
PostPosted: Sun Dec 19, 2010 7:55 am Up
Have a look under the bonnet for the ABS unit.
If its a Bosch one find the 10 digit ID number & post it up.
It will look something like X XXX XXX XXX
If it turns out to be the Bosch 2E system you can easily flash out the fault codes with the ABS dash warning light Wink
EDP407
PostPosted: Sun Dec 19, 2010 8:30 am Up
does it look like this? This si the only bosche thing i could see
It says:
Bosche 515
Code: 0 445 010 046
Mk1 Seat Leon Driver - Once a proud 206 driver!
EDP407
PostPosted: Sun Dec 19, 2010 9:35 am Up
Wise, kind people of 206info.co.uk I thank you for all your help once again! The problem is resolved. Thanks MrBSI for all your help, and "G."
Problem fixed by just melting away the snow that must have been blocking the ABS sensor
Lecktorious
PostPosted: Sun Dec 19, 2010 10:32 am Up
Trade Rating: +59
Snow trapped around the driveshaft?
'98 Nile Blue 306 GTi 6
Page 2 of 2
