Online Now [44]:
Visitors: 43
Today: 35024
Total: 117498575
Forums › The Car › 206 Problems › no heaters on speed 0 1 2 3
cosmicnutter
PostPosted: Sun Dec 19, 2010 6:08 am Up
my heaters have stopped working on speed 1 2 3, but work on 4. anyone know why this may be?
sam
PostPosted: Sun Dec 19, 2010 8:49 am Up
i knew someone who had the same problem and what had happened was that the cable which is behind the unit was a bit slack and only worked when he moved it to speed 3 and 4
if im right he went to a scrapyard and got a new heater control unit for like a fiver and changed that and it worked perfectly fine
if start by removing your centre console and checking the unit itself to make sure nothing has come loose
all the best with it
mjsroofing
PostPosted: Sun Dec 19, 2010 1:30 pm Up
i cant think what its called at the min but there will be a electrical thingy that controls the amount of power that goes to the motor normally you'll find it fitted in the heater matrix box its only an inch or so square and is normall easy to replace
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
chrisd
PostPosted: Sun Dec 19, 2010 1:41 pm Up
Reostat sp? I think its called, a wee resistor type thing very commin thing to go on cars heaters
macj
PostPosted: Sun Dec 19, 2010 2:06 pm Up
Ballast resistor
mjsroofing
PostPosted: Sun Dec 19, 2010 2:13 pm Up
as above
Mark
