Latest: sparrowdclxvi
Overall: 17139
Online Now [526]:
Visitors: 526
Today: 67965
Total: 112751906
Forums › The Car › 206 Talk › Heater Matrix Replace... Expensive
Danny.
PostPosted: Mon Dec 20, 2010 10:38 am Up
I have just gopt a quote for anew Heater Matrix Fitted.... £392 All in....
Ummm this isnt from peugeot either....
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
robdob
PostPosted: Mon Dec 20, 2010 10:46 am Up
sounds pretty steep, thats because they probably wanna take the whole dash off and steering column out etc to gain access. most people on here will advise to do it yourself. can be easy or hard but that does sound steep to me personally. me and my dad did mine
Rob2859
PostPosted: Mon Dec 20, 2010 10:50 am Up
rip off mate. shop around
Danny.
PostPosted: Mon Dec 20, 2010 10:51 am Up
Well im now waiting for peugeot to get back to me... I would fit it my self but i have no idea how.....
PostPosted: Mon Dec 20, 2010 10:55 am Up
You can get it out without removing the whole dash.
You need to remove the glove box compartment (glovebox door and inside lining). Once the lining is out, you can bend the dash trim that runs under the glovebox out of the way to slide the heater matrix in and out. It will easily bend once the glovebox liner is out and it will return to its original condition once you let go. Much easier than spending a day getting the dash out.
www.peugeotcentral.co....amp;t=1592
Danny.
PostPosted: Mon Dec 20, 2010 10:59 am Up
DJ if this works you are such a life saver.... i will owe forever lol... Its getting very cold Smile
Will i need anything apart from the heater matrix its self?
PostPosted: Mon Dec 20, 2010 11:01 am Up
Not sure if anything else close would need changing. Would be good to check servicebox diagram to see if there are any small components that may need changing whilst its all open?!
Danny.
PostPosted: Mon Dec 20, 2010 11:06 am Up
Yea good idea.. I also have a haynes manual and ill have a flick through that it should tell me.
PostPosted: Mon Dec 20, 2010 11:07 am Up
Might as well retrofit the glovebox light at the same time if you dont already have one Laughing
Danny.
PostPosted: Mon Dec 20, 2010 11:24 am Up
Doesnt bother me that much Smile
T_bandery
PostPosted: Mon Dec 20, 2010 11:27 am Up
Aww, unlucky man Sad
I couldn't get mine out without removing the dash
and then the dash itself takes up so much time to fit back as well!
PostPosted: Mon Dec 20, 2010 11:37 am Up
Wiring should already be there clipped to side of glovebox, simple plug & play with switch & light.
stevedude
PostPosted: Thu Jan 13, 2011 5:11 pm Up
so did you need anything else? gaskets or something?
Happydays
