Online Now [550]:
Visitors: 549
Today: 119952
Total: 157141646
Forums › The Car › 206 Problems › Over fueling?
Over fueling?
Go to page Previous  1, 2
wayne
PostPosted: Sat Dec 11, 2010 1:13 pm Up
the car stalls when you first start it and you here the revs going up and down sounds its being pumped a bit slow
my 206 drink petrol can you help?
wayne
PostPosted: Sat Dec 11, 2010 1:29 pm Up
any more ideas please Sad
wayne
PostPosted: Tue Dec 21, 2010 7:33 am Up
is any one on this helpful site
smiddies
PostPosted: Tue Dec 21, 2010 8:20 am Up
Well most of peoples knowleged is only from past situations, there has already been sme ideas why, if you have tested these ideas, and none have worked, then why not try what normal people do, and go to the garage!!
After all this is a car forum, and not just a problem solving forum!
wayne
PostPosted: Fri Dec 24, 2010 4:31 pm Up
ive been to a garage and there is no fault codes comeing up. that is why i am getting frustrated with the car. there's no need to be bitchey HELP............................................
mjsroofing
PostPosted: Fri Dec 24, 2010 4:39 pm Up
temp sensors it sounds like, have you had any coolant issues, there is more than one temp sensor too, some have three i think. check clean throttle body, check clean flywheel sensor,
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
Rob2859
PostPosted: Fri Dec 24, 2010 5:07 pm Up
02 or MAP sensor maybe. Although in fairness they should come up on the diag
wayne
PostPosted: Sun Dec 26, 2010 5:15 am Up
thanks lads. i have tried all of the above but not fly wheel sensor and a green temp switch were are the others
wayne
PostPosted: Sun Dec 26, 2010 5:16 am Up
sorry i have changed the green temp switch.
PostPosted: Sun Dec 26, 2010 5:40 am Up
Take it do a decent garage that actually know what there doing.
Just throwing new parts at the car is the wasteful way if trying to fix it.
Page 2 of 2
