Latest: heikkisj
Overall: 17126
Online Now [382]:
Visitors: 381
Today: 34822
Total: 100367778
Forums › The Car › 206 Talk › Anyone ever repaired a heated rear windscreen?
Mike
PostPosted: Tue Dec 21, 2010 10:15 am Up
Trade Rating: +28
Two of my lines on the HRW aren't working so looking at trying to repair them, saw this guide below from another forum and guessing it's pretty similar for all cars but wondered had anyone tried it on a 206 and got any tips etc?
Cheers.
www.retro-renault.com/...epair.html
Danw_VVT
PostPosted: Tue Dec 21, 2010 10:18 am Up
brian was talking about them tbh i need to get one
sillyhilly
PostPosted: Tue Dec 21, 2010 10:52 am Up
Cheers.
It's easy! Think of it as a cross between painting with a fine brush and soldering.
With that guide, it says it all. You don't need any tips to be honest!
Hi Mikey Smile
namgaj
PostPosted: Tue Dec 21, 2010 10:55 am Up
Id be tempted to "mask" a thin line with masking tape if you get me, so it doesnt look a mess!
4.0 V8 S-Type Jaguar
meady
PostPosted: Tue Dec 21, 2010 11:11 am Up
Trade Rating: +45
Thts what i was thinkong because then you couldjust paint over the tape a bit and when you peal it off it would (hopefully) leave a nice neat line there
TEAM - I HATE FACEBOOK Smile
MrrNoName
PostPosted: Tue Dec 21, 2010 2:54 pm Up
Hi,
ive repaired a few rear screens using this:
www.halfords.com/webap...yId_165746
it does work, however the repair is noticable as its a bright silver line and not dark brown. the stencil that comes with the kit is useless.
i attempted to mask the area but found it difficult to get a good masking line because the lines on the window were not straight but curved up at the edges.
you can find any breaks by visually looking, breaks in the lines appear bright orange instead of dark brown.
you can also find breaks in the lines using a 12v bulb in a bulbholder. connect one wire to ground (such as the boot latch) and run the other wire from the bulbholder along the lines of the window. the bulb should be lit up brightly at the beginning of the line (on the left hand side) and progressily get darker as you run the wire across. if the bulb suddenly goes out you have found a break.
i found it easy to repair small i.e 1-5mm breaks but very difficult to repair large breaks as the paint gets messy when attempting to do a long line
also when the paint dries it forms a hard metal consistancy. its not really possible to paint over masking tape and peel the tape off leaving a straight line. it either rips the tape or breaks all of the paint off.
it is difficult stuff to work with. however does repair the window well if its done right. you should have a go, providing the breaks arnt too large.
