Posted: Wed Dec 22, 2010 5:22 am |
Can anyone help ??
When i bought my 206 van about ayear and a half ago ,
i only got one key with it ,
I have contacted peugeot to get a spare but been quoted over a hundred quid for a spare !!!
It is just a normal key (as in doesnt have central locking or buttons on it )
I know there is some kind of microchip in it !!
Does anyone know of anywhere i can get one cheaper than that
Regards
Baz206
Posted: Wed Dec 22, 2010 5:29 am |
Just go get one cut :s
| PM me for Valeting & Detailing services at great rates!
Detailing Guides are also available ask me for more information. | |
Posted: Wed Dec 22, 2010 5:48 am |
your cheaper to actually pay up the 100 now to get a copy.
id also get a blade only one from a normal key cutter so u can at least get into your car,
because once you loose your last set of keys you will then have to change all locks, ecu , new keys , program new keys which will cost even more
Posted: Wed Dec 22, 2010 5:54 am |
leon206 wrote: |
because once you loose your last set of keys you will then have to change all locks, ecu , new keys , program new keys which will cost even more |
you wouldnt have to replace all that, at all. You just find out your PIN for the immobilser , and the key blade number, and just get another one cut.
Posted: Wed Dec 22, 2010 6:04 am |
[quote="qwert"]
leon206 wrote: |
you wouldnt have to replace all that, at all. You just find out your PIN for the immobilser , and the key blade number, and just get another one cut.[/quote
How would i find the immobiliser and key blade number ???
Posted: Wed Dec 22, 2010 6:22 am |
Whats your chassis number? I'll try and get it for you.
Posted: Wed Dec 22, 2010 8:48 am |
A normal transponder key cut to the car is around £20 from Peugeot.
It's the coding it to the immobiliser that cost's
Posted: Wed Dec 22, 2010 12:18 pm |
[quote="Lee"]Whats your chassis number? I'll try and get it for you.[/quote
Hi lee that would be xlnt
chassis number is VF32SWJZW40992443 ,
Also where would i get this done ???
Posted: Wed Dec 22, 2010 12:22 pm |
Just requested it now, I'll let you know when I get a reply.
A auto locksmith/key cutter should be able to do it.
Posted: Wed Dec 22, 2010 12:24 pm |
Lee wrote: |
A auto locksmith/key cutter should be able to do it. |
cheers mate !!
Posted: Thu Dec 23, 2010 7:37 am |
Transponder code and key code sent in PM
