Latest: heikkisj
Overall: 17126
Online Now [101]:
Visitors: 100
Today: 19121
Total: 100352084
Forums › The Car › Solved 206 Problems › Rear lights
Rear lights
pwbadi
PostPosted: Wed Dec 22, 2010 11:14 am Up
My car failed its MOT due to a non functioning Brake light. I replaced the bulb and it is still not working.
What I have now realised is that the circuit board( On to which the bulbs are fixed) is full of rust. Cleaned it withn WD 40 and it still isn't working.
Called the dealer and was told that I need to buy the whole unit at a cost of £86. But one of my mates got just the board for a 306 recently.
Has anyone had this issue before? And how did you resolve it. ( cleaning does not seem to be an option)
Many thanks in advance
206 1.4 Hdi
PostPosted: Wed Dec 22, 2010 11:16 am Up
If you cant clean it, nor re-wire it. Just get some 2nd hand lights, you can pick phase one's up for a tenner.
PostPosted: Wed Dec 22, 2010 12:21 pm Up
both brake lights don't go on,or just one side??,because if the 2 are not working,then you need to check the brake trigger behind the brake pedal
drunknmunky
PostPosted: Wed Dec 22, 2010 1:06 pm Up
ive got some for sale that i need to get rid of cluttering up my dads front room you can have em for a tenner Smile
pwbadi
PostPosted: Wed Dec 22, 2010 1:18 pm Up
Thank you all for the replies. When Lee mentioned re-wiring, I decided to solder 3 wires to the bulb and connected them to the main socket from the wire harness. And it worked. Thanks once again
206 1.4 Hdi
