Posted: Thu Dec 23, 2010 4:46 pm |
Right, this afternoon i had the battery disconnected to install an amp, and now it wont start
Some details:
Turns over
All lights are on as usual
No sound from fuel pump
Big red button is fine
BSI Reset has been done
Is there any way to test the fuel pump from inside the car, i have an install covering the hatch to access it! ffs lol
Ps, all fueses are fine
Please Help! Sam.
Posted: Thu Dec 23, 2010 5:07 pm |
Some more info.
The 4 wires going into the pump area read
0v
0v
0v
3v (which i assume is the supply for the fuel level sender)
Sam.
Posted: Fri Dec 24, 2010 3:56 am |
Everything points to a fuse blown during the installation, i would be checking the fuses again and looking for an independant' fuse possibly missed the first time.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Fri Dec 24, 2010 4:03 am |
Get ya multimeter out and check the feeds to your fusebox in the engine bay, starter motor etc
Posted: Fri Dec 24, 2010 6:52 am |
No fuses gone.
main feed is ok, there is no feed from the multi function relay to the fuse box, so this points towards the relay or whatever controls it, ECU?
Sam.
Posted: Fri Dec 24, 2010 6:58 am |
Is the key in ignition warning still working when you open the drivers door with the ignition turned OFF?
Posted: Fri Dec 24, 2010 7:01 am |
Yes it is
Posted: Fri Dec 24, 2010 7:03 am |
Then the immobiliser is working correctly then.
If your sure its not a fuse then replace the multifunction relay
