Latest: S2cgm
Overall: 17178
Online Now [476]:
Visitors: 475
Today: 148983
Total: 136170201
Forums › The Car › 206 Problems › Rear brake lines
Rear brake lines
T_bandery
PostPosted: Fri Dec 24, 2010 11:16 am Up
I am removing the old rear axle of my 206 but have run into a problem, the rear brake line nut wont open.... the spanner is just rounding the nut off...Any tip and tricks you info'ers would like to share?
Its a 206 1.4 (very basic model, no abs) and has a small box attached to the axle to which regulates the brake fluid to the brakes and none of the nuts for the brake line open Crying or Very sad
PostPosted: Fri Dec 24, 2010 11:26 am Up
Use a proper brake pipe spanner!
PostPosted: Fri Dec 24, 2010 11:48 am Up
I agree! What He Said
There cheap enough to buy, Halford's sell them if your stuck.
Its annoying when you go to undo one & find someone else has been there before with the wrong spanner & ruined the union Twisted Evil
T_bandery
PostPosted: Fri Dec 24, 2010 1:06 pm Up
Already tried the 11mm brake spanner and it was no use, jut rounded the nut off even more Sad
T_bandery
PostPosted: Fri Dec 24, 2010 1:13 pm Up
Anyone know where to get the metal lines and the brake pipe union nuts??
panason1c
PostPosted: Fri Dec 24, 2010 1:34 pm Up
Any well equipped garage/workshop will have the 'flaring tool' to make them up for you.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
jimbo2470
PostPosted: Fri Dec 24, 2010 2:26 pm Up
just use a pair of mulgrips.. worked for me when doing renault clio rear cylinders.. (these are renowned for seizing..)
Gotta love french....
mjsroofing
PostPosted: Fri Dec 24, 2010 2:50 pm Up
as above but use some wd40 first leave it soak in for 10 mins
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
giveitsomebar
PostPosted: Fri Dec 24, 2010 5:19 pm Up
yeah if its got to the point where its rounded off the line will be shagged anyway soak it in wd and brute force it with some molgrips and get another line made up
KrisB
PostPosted: Sat Dec 25, 2010 12:37 pm Up
Molegrips should do it, if you need the pipes changed i'm happy to do it for you and make up some new lines. I've got all thats needed on the shelf.
French car specialist. West Sussex. www.KrisB.co.uk
