Posted: Mon Dec 27, 2010 10:00 am |
Hi All,
Firstly Happy Crispo to one and all & have a fab 2011.
I re-charged the pugs battery and then entered the wrong radio code x 4 times. I have the code now - it was left at home whilst driving somewhere for a family Christmas.
Can anyone help with Ideas - how to re-set the system - So I am not locked out of my radio system?
Thanks.
I have dissconnected the Pugs Battery doing this for 1 Hour to reset the System. So I hope this might work!
Posted: Mon Dec 27, 2010 10:04 am |
I'm pretty sure you have to leave the ignition on & radio powered up until it times out & resets to ask for the code.
Posted: Mon Dec 27, 2010 10:30 am |
Hi,
Yes your right. I just read that in my manual. the timing out is either 5 miutes or up to 1 hour!
But I drove for up to 1 hour with the radio system not clearing.
I'll have to try again.
Thanks for the help.
Posted: Mon Dec 27, 2010 12:09 pm |
my old one took about 2 hours to clear once. Took it out of the car and put it in the garage connected to a spare battery for a day.
Posted: Mon Dec 27, 2010 12:26 pm |
perfect excuss to upgrade your h/u :)?
Posted: Mon Dec 27, 2010 1:05 pm |
I have a standered tape and radio player for the 206 £20 posted mate and you can have it.
Posted: Mon Dec 27, 2010 2:29 pm |
Yes It is a great excuse to upgrade the H/Unit. AM just checking this one out...http://www.dynamicsounds.co.uk/pioneer-mvh8200bt-bluetooth-digital-media-receiver-3inch-p-11541.html
Posted: Tue Dec 28, 2010 8:41 am |
had this probably recently. it takes longer to unlock each time it is locked. can take days lol! as said before, best to take it out and plug it into a 12 power source to wait for it to clear. once its clear put in the correct code then turn it off, put it back in the car and enter the correct code. done
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Mon Jan 24, 2011 10:00 am |
I need to leave mine wired up to a battery does anyone know of the top of their heads which 2o terminal pins are Pos n Neg on the rerar of the unit? I have another stereo fitted to the car at the mo otherwise Id just blook at the wiring loom. Thanks.F
Posted: Mon Jan 24, 2011 12:30 pm |
If you can't tell the difference between a positive and negative feed, should you really be messing with the electrics?
