Posted: Tue Dec 28, 2010 12:30 pm |
girlfriend has 1.1 2004 206. yellow engine light is on but car is running perfect. the oil was very low (off the dip stick)!. topped up with oil now showing full. would this have caused the engine management light to come on? if so hoew can i get rid of the light now? cheers
Needs a code scan, your just guessing unless you have the codes read
Posted: Tue Dec 28, 2010 12:31 pm |
Needs a fault code scan.
[/end thread]
Posted: Tue Dec 28, 2010 12:34 pm |
would the aa be able to read the code if she called them out?
Posted: Tue Dec 28, 2010 12:35 pm |
Yes
Posted: Tue Dec 28, 2010 12:36 pm |
| hampshire1 wrote: |
| would the aa be able to read the code if she called them out? |
Yes, they should be able to but they wont be to happy unless the cars actually broken down
Posted: Tue Dec 28, 2010 12:40 pm |
do you know if low oil sets the engine manegement light off?
Posted: Tue Dec 28, 2010 12:41 pm |
Shouldnt do, who knows what codes the ecu has stored
Then again the oil level gauge on the dash at start up gives plenty of clues to the engine oil level
Posted: Tue Dec 28, 2010 12:58 pm |
why to call AA to read you the codes,while your GF car is running perfect as you said,the AA for help on the road when your car is broken down.
So take it to the garage or the dealer instead of guessing,because such light on the dash can be cause by hundreds of things,and only diagnostic software can tell you what it's for sure,good luck.
Posted: Tue Dec 28, 2010 1:02 pm |
| Timon2210 wrote: |
So take it to the garage or the dealer instead of guessing,because such light on the dash can be cause by hundreds of things,and only diagnostic software can tell you what it's for sure,good luck. |
They have paid the fee for the AA already, so why pay again?
Posted: Fri Dec 31, 2010 6:10 am |
| Lee wrote: |
| Timon2210 wrote: |
They have paid the fee for the AA already, so why pay again?  |
