Latest: dreyfalon
Overall: 17121
Online Now [44]:
Visitors: 43
Today: 63818
Total: 97744322
Forums › The Car › 206 Problems › 206 changing gear + steering = suicide
PostPosted: Tue Dec 28, 2010 5:36 pm Up
mjsroofing wrote:
my mate is a pug machanic and he said he has known them to go as quick as a month or two with aftermarket, he laughed at me when i said that i used aftermarket ones.
Joys, thanks for the info mate
But hopefully it wont be them, cant really afford it as i know it will fail with honors Laughing
Ste
PostPosted: Tue Dec 28, 2010 5:47 pm Up
Staff - Ste
'tis true I'm afraid aftermarket wishbones are pap Sad Mine have been on less than a month and are already showing signs of wear Laughing
The Cars:
NICKST
PostPosted: Tue Dec 28, 2010 5:54 pm Up
My van did this and was the gearbox diff just giving power to one wheel the it would do both every now and again get the diff checked.
robertmarcs
PostPosted: Tue Dec 28, 2010 6:51 pm Up
same here! would pull under acceleration to one side then snap back when i lifted off! changed wishbones to genuine ones and changded droplink n all is fine now! u could also check the gearbox mountings to be on the safe side btw
EdCherry
PostPosted: Tue Dec 28, 2010 6:52 pm Up
Lower arms.
Cheap aftermarket ones are s**te, been there done that.
mattievrs
PostPosted: Tue Dec 28, 2010 6:55 pm Up
check the cv joints for lack of grease aswell as checking the gearbox oil level and wouldnt hurt renewing it too.
NO LONGER ACTIVE ON THE FORUM
GP-F
PostPosted: Tue Dec 28, 2010 7:39 pm Up
Any idea of cost from Peugeot? GSF ones fitted previously (not the cheapest ones they offered either). Discounts available??
206CC
imjeeves
PostPosted: Wed Dec 29, 2010 7:34 am Up
It sounds v much like wishbones. The aftermarket ones are poor and the bushes break very quickly. I have heard of them going in less than a week in some cases. Its just your luck if you get a good set
PostPosted: Wed Dec 29, 2010 7:39 am Up
lemforder wishbone from eurocarparts is good as the one from pug dealer
GP-F
PostPosted: Thu Dec 30, 2010 10:39 am Up
£100 EACH..hope its not them Sad
206CC
PostPosted: Thu Dec 30, 2010 10:42 am Up
Genuine Peugeot one's are only slightly more.
Last changed mine back in 2005 / 50k miles ago, fit genuine part's & they last Cool
mjsroofing
PostPosted: Thu Dec 30, 2010 10:52 am Up
i wouldn't pay £100 each for them though i must admit, i bought two off fleebay for £40 posted, i'd hope for the best. big risk i guess though, at least if pug ones fail you can return them. well i guess you can, i would hope so for that price
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
GP-F
PostPosted: Thu Dec 30, 2010 11:09 am Up
without sounding too dumb, what exactly should I be looking for (bearing in mind I dont have ramps - but a trolley jack & axle stands)?
Splits in rubber joints? out of position mounts?
206CC
mjsroofing
PostPosted: Thu Dec 30, 2010 11:39 am Up
ok, below is a pic of the wishbone, the rubber joint arrowed is normally twisted badley and cracked etc
hope this helps.
Mark
PostPosted: Thu Dec 30, 2010 3:13 pm Up
Well, mine had an MOT and i specifically stated for them to go over with a fine tooth comb
They did, and found that the bottom arms had no play, same with anyother suspension areas
Page 2 of 3
