Latest: sparrowdclxvi
Overall: 17139
Online Now [155]:
Visitors: 154
Today: 19715
Total: 113351738
Forums › The Car › 206 Talk › PowerFlow Exhausts
PowerFlow Exhausts
JDave
PostPosted: Fri Dec 31, 2010 7:55 am Up
Hi,
Looking at getting one. I don't want a loud one at all. I want something subtle.
I am on the website but its difficult to work around. Anyway, how much are they going for brand new? Do you need to go to a store?
And a question I have always wanted to know, How can you tell how loud an exhaust is before you fit it?
JD
Click To View My Project
PostPosted: Fri Dec 31, 2010 8:11 am Up
Are you after a full system or just the backbox?
MrZiggerz
PostPosted: Fri Dec 31, 2010 8:19 am Up
I went to the nearest shop and told them how I wanted it to sound and then gave me a quote, he also said if it doesn't sound how you want come back and we will change it. Also lifetime garuntee Smile
Bigger the pipe louder it will be.
JDave
PostPosted: Fri Dec 31, 2010 8:25 am Up
Just the backbox.
russman
PostPosted: Fri Dec 31, 2010 8:32 am Up
mate i'm looking at getting a sportex exhaust, have a look at them they seem a nice make.
www.sportex-exhausts.c...gory_id=11
Thanks,\r\nRussell
NICKST
PostPosted: Fri Dec 31, 2010 8:41 am Up
I have a full powerflow system on my 180 sounds just right and any problems for as long as you own the car that will fix it free of charge.
I'd get an off the shelf system as they are higher quality generally.
MrZiggerz
PostPosted: Fri Dec 31, 2010 8:55 am Up
JDave wrote:
Just the backbox.
No point using powerflow if you just want a backbox
Chris180
PostPosted: Fri Dec 31, 2010 8:57 am Up
i have a cat back system from powerflow, it has a nice tone to it but when you get a look at the pipework under the car it's not brilliant, it also set me back £340, i would probably go for janspeed if i was to ever replace it
2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread
JDave
PostPosted: Fri Dec 31, 2010 8:58 am Up
Where can I get stainless steal exhausts for a 206, prefrably twins?
amy-v17
PostPosted: Fri Dec 31, 2010 8:59 am Up
Before you go anywhere near powerflow I have literally spent all morning sorting mine out just uploading the pics to photobucket and you will see what I mean, and it went to a specialist powerflow garage to be done! DONT DO IT lol
NICKST
PostPosted: Fri Dec 31, 2010 9:05 am Up
That's just down to the people that work at the branch you went to. Myna been on the car for 4 years now never had a single problem with it and the workmanship is second to non. When I take it back every year for it's warranty check they even polish the back box to make it shiny again.
PostPosted: Fri Dec 31, 2010 9:37 am Up
Powerflow and other custom outfits do not use mandrel bends. So you new system could well be more restrictive that the original system.
JDave
PostPosted: Fri Dec 31, 2010 9:43 am Up
PostPosted: Fri Dec 31, 2010 9:45 am Up
My P'flow backbox was £120 fitted inc bumper cutting etc. Yes you have to go to a dealer they make and fit them while you wait. They can judge how loud it will be by the size of the pipes and the backbox, if you said you want it subtle they would make it subtle
I can't speak for others obviously but i was very impressed with the work it's all high quality, inc the bumper cutting and seems great value to me Thumb Up i'd definitely recommend them!
Here's mine:
