Online Now [429]:
Visitors: 427
Members: 1
Today: 71482
Total: 155941870
Forums › The Car › 206 Problems › ECU?
ECU?
PostPosted: Fri Dec 31, 2010 8:24 am Up
Looks like a sticker is missing from in the middle.
grantjohn1979
PostPosted: Fri Dec 31, 2010 8:32 am Up
does indeed but this is the thing if im going to get another ecu off ebay mayb what do i go by? that its a peugeot 206 1.4 ecu? or my vin number etc? any ideas guys thanks
n/a
PostPosted: Fri Dec 31, 2010 8:35 am Up
Use the VIN number to find the correct ecu part number.
Log in to Peugeot Service box & use your vin number to search for parts Wink
Or you can PM me the vin & ill have a look if you want.
grantjohn1979
PostPosted: Fri Dec 31, 2010 8:44 am Up
mr bsi heres my vin number fella pm me or just continue on here vin number is VF32AKFXE40010001 thanks
n/a
mjsroofing
PostPosted: Fri Dec 31, 2010 8:46 am Up
very helpfull of you mrbsi
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Fri Dec 31, 2010 8:57 am Up
basically it's a choice of 2
Has it got a lambda sensor on the exhaust manifold?
1929 QP if it doesn't
1939 AH if it has
Id still be tempted to send the original way to be tested first Wink
grantjohn1979
PostPosted: Fri Dec 31, 2010 9:09 am Up
lambda sensor is in the front down pipe which joins onto the manifold not the actual manifold itself so im presuming 1939ah?
n/a
PostPosted: Fri Dec 31, 2010 9:12 am Up
So you have a total of 2 lambda sensor's?
One before the cat & a second after the cat?
grantjohn1979
PostPosted: Fri Dec 31, 2010 9:30 am Up
just the one on the front down pipe mate
n/a
PostPosted: Fri Dec 31, 2010 9:35 am Up
Should be 1929 QP then
I would check that part number with a Peugeot main dealer though!
grantjohn1979
PostPosted: Fri Dec 31, 2010 10:09 am Up
just rang them up and they mentioned this number 1929 rf?
n/a
PostPosted: Fri Dec 31, 2010 10:12 am Up
Go with that one then, they have better access to more of Service Box Wink
PostPosted: Fri Dec 31, 2010 10:21 am Up
It's to do with the emission system and settings as to why they differ.
crb84
PostPosted: Fri Dec 31, 2010 10:29 am Up
ECU
the problem i had was the car would start when it felt like it, found out the ecu was not telling the feul to go through when i was trying to start the car, found out the ECU was nackered after sending it of to be tested (www.the-ecu-doctor.co.uk) and needed to replace it, a friend of mine is an auto electrician and told me i'd need to replace it with the exact same ecu as a diferent one could not be coded in to my key, long story short i found an ecu kit on ebay (ecu, alarm module, ignition ring chip and circuit board from key) with the same part number as mine, cost me £100. Now the thing is i can swap the parts over myself but i cant find where the immobiliser/alarm module is in the car, anyone know???
ps. the photo u put on of your ecu, the numbers u need are underneath the ecu u will need to take it out and have a look! (there is another sticker on the bottom)
crb
PostPosted: Fri Dec 31, 2010 10:31 am Up
What year is your 206?
2 totally different electrical systems used Wink
Page 2 of 3
