Latest: heikkisj
Overall: 17126
Online Now [55]:
Visitors: 54
Today: 8891
Total: 100381645
Go to page Previous  1, 2, 3, ... 9, 10, 11  Next
Austin
PostPosted: Sun Feb 14, 2010 1:22 pm Up
Damn them rear arches are wide! Surprised
Chi
PostPosted: Sun Feb 14, 2010 1:27 pm Up
WOW! Nice work so far. What engine are you gonna stick in there? What will be the base for the engine?
Please feel free to send any suggestions or general feedback to feedback206@email.com
PostPosted: Sun Feb 14, 2010 2:27 pm Up
Like the thread, but as i said before on the previous Info
Im still not sure on the safety factor of aftermarket welding Confused
Who knows it could be brilliant, but it could be utter rubbish
Good luck Smile
briant
PostPosted: Fri Dec 31, 2010 5:47 pm Up
This project hasnt been touched in nearly 12 months due to work and other committments,This has to be the longest running rallycar built ever Very Happy
but i got some time to dust it off and get few bits done in last few weeks
there was a lot of work cutting & modifing to get fiberglass front wings and bumper to fit
eventually i got it fitted ok,so started on making wiring looms you can see from pics the loom was just a ball of wires
so i just cut all required connections from orignal loom and cut the wires as i need them from the loom(Bit of recycling Very Happy ) even though i used the wiring and connections from orignal loom when i was finished making the loom i still had a awful lot of orignal wiring left over, so im pretty happy with decision to make a custom loom and the result as every bit of excess weight removed is a good job Smile
I really hope i can get the time to keep working on this and get it finished
plan is to fit engine and make looms for throttle boddies & ignition then remove engine for full rebuild and tape up all the loom anyway enuf with the chat heres the pics
Pic of the front mocked up
This is what i had left over from orignal loom
The orignal loom
206 Rallycar
imjeeves
PostPosted: Sat Jan 01, 2011 5:45 pm Up
Good work. I am doing the wiring just now and hate the stuff. Good to see another rally boy on here
RidingSoLow
PostPosted: Sun Jan 02, 2011 4:59 am Up
WRC Bodykit FTW! Guna be sick!
Suspended
macj
PostPosted: Sun Jan 02, 2011 10:01 am Up
Nice to see you chose the Acer dash and Mtech ECU...... top man. Did he send you the ECU with a base map?????
Lecktorious
PostPosted: Sun Jan 02, 2011 10:07 am Up
Trade Rating: +59
Is that a genuine Dimma kit?
'98 Nile Blue 306 GTi 6
imjeeves
PostPosted: Sun Jan 02, 2011 12:47 pm Up
I would love to fit this kit but from past experence I seem to hit a lot of stuff and all that work to move the wheels out is far too complicated for me.
macj
PostPosted: Sun Jan 02, 2011 1:13 pm Up
I would be worried about logbooking after my ordeal with the spoiler. But you may be fine. Its a lot to wreck on the nearest tree Shocked
briant
PostPosted: Sun Jan 02, 2011 1:27 pm Up
Yep ecu has a base map id be guessing it one of the maps he started with on your car tbh i have the ecu and tb's 12mths or so i think the V3 is nearly obsolete at this stage
I think it was you who posted a link to the dash in your orignal build thread Razz
206 Rallycar
briant
PostPosted: Sun Jan 02, 2011 1:29 pm Up
no a fiberglass copy and TBH not a very good fit had a lot of cutting to do to get it fitted ok its ok for track or rallycar but not for road car
206 Rallycar
macj
PostPosted: Sun Jan 02, 2011 1:30 pm Up
Glad it helped..... one thing to make sure of is the earthing... I had an issue with the coil drivers going pop because the main earth points were not good enough and it earthed thru the drivers and knocked em out. The Acer is a good bit of kit... you can get the rev limiter and shift light to calibrate with the ECU software and it is more than good enough for rally work.... bit bright at night though
briant
PostPosted: Sun Jan 02, 2011 1:32 pm Up
i started off building a Gp A7 spec but as soon as i got carried away with WRC kit i changed to Modified so anything goes with it as im not logging it as GpA
Shocked Dont mention trees that what happened to my widetrack nova Crying or Very sad
206 Rallycar
macj
PostPosted: Sun Jan 02, 2011 1:33 pm Up
love it...... will be a treat to drive with the wider track
Page 2 of 11
