Latest: S2cgm
Overall: 17178
Online Now [359]:
Visitors: 359
Today: 56529
Total: 136528006
Go to page Previous  1, 2, 3 ... 6, 7, 8 ... 31, 32, 33  Next
st3v3n
PostPosted: Sun Jan 02, 2011 4:30 pm Up
Well done on 1000 posts btw haha
ICE goes in drinks. NOT in cars.
imjeeves
PostPosted: Fri Jan 07, 2011 3:13 pm Up
What size of throttle body trumpets are you using mate?
macj
PostPosted: Fri Jan 07, 2011 3:37 pm Up
90mm rings a bell.... I not looked at my trumpets lately Very Happy
imjeeves
PostPosted: Fri Jan 07, 2011 3:46 pm Up
Did you have to move the radiator out the way for that length?
macj
PostPosted: Sat Jan 08, 2011 4:27 am Up
Yes.... I fitted a toyota corolla rad, lowered the Xmember and made new top brackets and with no A/C to worry about you get a few inches forward too
macj
PostPosted: Sun Jan 09, 2011 12:04 pm Up
Bit more progress today.... stripped out a spare gearbox and fitted the quaife ATB LSD and bought a better ratio CWP which means the car will now have a final drive ratio of 4.176:1.... should give it a little more zip out of the corners Very Happy
st3v3n
PostPosted: Sun Jan 09, 2011 2:07 pm Up
What did you get that CWP out of? and what torque did you tighten the CWP bolts up to?
When I took mine out they were proper f****d. The threads were almost stripped and when I ordered more they have now been superseded. Couldn't find any proper info so took them to 105Nm
imjeeves
PostPosted: Sun Jan 09, 2011 2:19 pm Up
I have a 4.4 cwp mate if you are looking for one?
st3v3n
PostPosted: Sun Jan 09, 2011 2:31 pm Up
What's the standard one? I need to spend a bit more time with mine as it is now and see how I feel it needs improving.
macj
PostPosted: Sun Jan 09, 2011 2:42 pm Up
Its out of a Citroen Berlingo 1.6... as for the bolts, They always look stripped when you take em out, I usually take them up to 100Nm with studlock
macj
PostPosted: Sun Jan 09, 2011 2:45 pm Up
Price mate.... would be good for gravel spec
macj
PostPosted: Sun Jan 09, 2011 2:48 pm Up
Standard is 3.8:1 approx I think
imjeeves
PostPosted: Mon Jan 10, 2011 9:02 pm Up
Yeh standard is 3.8 which has really poor acceleration I found. We have a 4.89 fitted in our car and use a 4.4 if it is really high speed tarmac as we would be on the limiter all the time otherwise.
4,4 cwp is £150
st3v3n
PostPosted: Wed Jan 12, 2011 2:43 am Up
What max speed do you get with the 4.4? Mine currently bounces off the limiter at 130 in 5th lol
macj
PostPosted: Wed Jan 12, 2011 3:20 am Up
I usually gear for 100mph on the straight on the soft limiter.... most clerks of the course try to aim at 90mph maximum and will whack a chicane in the longer straights to acheive this. Not sure what you would get with a 4.4 but it may be close if you have your limiter set at 7000rpm on 600mm wheels
Page 7 of 33
